LG 29" Black Full HD LED Monitor 2560 x 1080 2x 5W Speak...
LG 29" Black Full HD LED Monitor 2560 x 1080 2x 5W Speaker Dis
£294.01
37 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 4-screen split
  • Dual link up
  • Smart energy saving
  • Flicker-safe
  • Reader mode
  • Diagonal Size: 29in
  • Max Resolution: 2560 x 1080
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, HDMI
Product codes
Efficiently run several programs and have multiple active windows on the screen at the same time.
For business meetings, the Dual link-up feature allows two portable devices, such as a computer, camera, phone or Blu-ray player to be connected to the monitor and used on a single screen simultaneously.
LG's smart energy saving mode reduces power consumption without lowering the brightness of the monitor.
Product Description LG 29UB67-B - LED monitor - 29"
Device Type LED-backlit LCD monitor - 29"
Energy Class Class C
Energy Consumption per Year 62 kWh
Power Consumption (On mode) 43 W
Panel Type AH-IPS
Aspect Ratio 21:9
Native Resolution 2560 x 1080 at 60 Hz
Pixel Pitch 0.264 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors 2xHDMI, DVI-D, DisplayPort
Speakers Integrated
Display Position Adjustments Height, pivot (rotation), tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Matte black
Dimensions (WxDxH) - with stand 70.3 cm x 25.23 cm x 40.4 cm
Weight 8.6 kg
Environmental Standards TCO Certified Displays 7, ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, UL, TUV GS, cUL, EN 61000-3-3, EN55024, DDC/CI, Directive 2006/95/EC, EN 61000-3-2:2006, EN 60950-1:2006, EPA 6.0, EMC 2004/108/EC, EN55022:2006 Class B, DIN ISO 9241-307
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG 29" Black Full HD L...
£294.01
