LG 29UM69G 29" 2560x1080 1ms HDMI DisplayPort USB-C Ultr...
LG 29UM69G 29" 2560x1080 1ms HDMI DisplayPort USB-C UltraWide IPS LED Monitor
£300.85
Delivery:
Key features
  • Gaming monitor with 1 ms motion blur reduction
  • Fluid gaming motion: AMD FreeSync technology
  • DAS mode
  • Black stabilizer
  • Game mode
  • The mighty design of the monitor
Product codes
Bundle deals (1)
TPLINK 25W 5-PORT USB CHARGER
LG 29UM69G 29
LG 29UM69G 29" 2560x1080 1ms HDMI DisplayPort USB-C...
£300.85
= £313.85
Save £3.00
Gaming Monitor with 1ms Motion Blur Reduction
Now gamers can achieve superb gaming graphics through the long-awaited combination of 21:9 UltraWide IPS and 1ms Motion Blur Reduction.
Fluid Gaming Motion: AMD FreeSync Technology
You can play without a frame loss with AMD FreeSync Technology, which eliminates tearing and stuttering that occur from the difference between a graphics card’s frame rate and monitor’s refresh rate.
A Variety of Gaming Features to Win: DAS Mode
The Dynamic Action Sync mode allows users to instantly attack the opponent without delay. It synchronizes your senses with real-time scenes happening in a fast-paced game by minimizing input lag. without delay. It synchronizes your senses with real-time scenes happening in a fast-paced game by minimizing input lag.
Gaming Features to Win: Black Stabilizer
While playing shooting games, the Black Stabilizer gives gamers full visibility even in deep-dark scenes. It automatically senses the darkest side and makes it brighter so that you can find the enemies hiding and waiting to attack you in the dark.
A Variety of Gaming Fetures to Win: Game Mode
With the Game Mode option in Picture Mode, you can customize the picture quality for various gaming genres such as FPS Game1, FPS Game2, RTS Game and Custom Game.
The Mighty Design of The Monitor
LG’s Gaming Monitor has design features thatfit well into your gaming station setup without hindering your gaming. The mighty design of the monitor with V-line stand and red colour produces a space where the gamer can be immersed deep into the game.
LG 29UM69G - LED monitor - 29"
LED-backlit LCD monitor - 29"
Energy Class
Class A
Energy Consumption per Year
41 kWh
Power Consumption (On mode)
28 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
UW-UXGA 2560 x 1080 at 75 Hz
Pixel Pitch
0.2628 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
14 ms (typical); 5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare, 3H Hard Coating
High glossy black
70.25 cm x 20.41 cm x 41.5 cm
5.5 kg
Plug and Play, FCC Class B certified, UL, TUV, cUL, CCC, DDC/CI, ERP, EPA 7.0
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG 29UM69G 29" 2560x10...
£300.85
