LG 29WK500 29" 2560x1080 5ms DVI HDMI DisplayPort USB-C...
LG 29WK500 29" 2560x1080 5ms DVI HDMI DisplayPort USB-C Thunderbolt UltraWide IPS LED Monitor
£266.66
39 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Play games with optimized settings
  • Clearer, smoother image
  • Versatile elegance
  • Diagonal Size: 29in
  • Max Resolution: 2560 x 1080
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: HDMI
Product codes
More Space for Multi-Tasking
The 21:9 UltraWide™ Full HD resolution (2560X1080) offers more screen space compared to 16:9 Full HD resolution display. You can run multiple windows and see more thumbnail images at once.
True Colours and Wider View
LG IPS monitor displays impeccable colour accuracy. With a wider viewing angle, the IPS display boasts 99% coverage of the sRGB colour spectrum.
Unified Interface for Easy Set-up
OnScreen Control gives quick, easy access to a host of important monitor settings.
Clearer, Smoother Image
With AMD FreeSync™ Technology, gamers can experience seamless, fluid movement during hi-res, fast-paced games. FreeSync virtually eliminates screen tearing and stuttering.
Optimized settings for all games
Game Mode includes three sub-modes-FPS, RTS, and Custom- for personalizing your gaming experience or optimizing your favorite game genres.
Versatile Elegance
The curved base is an elegant style statement that also enhances stability for dependable performance. The base can be adjusted to change the tilt, height and angle of the monitor for a more comfortable viewing experience.
Product Description LG 29WK500-P - LED monitor - 29"
Device Type LED-backlit LCD monitor - 29"
Energy Class Class A
Energy Consumption per Year 41 kWh
Power Consumption (On mode) 28 W
Adaptive-Sync Technology AMD FreeSync
Panel Type AH-IPS
Aspect Ratio 21:9
Native Resolution UWFHD 2560 x 1080 at 75 Hz
Pixel Pitch 0.2651 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors 2xHDMI
Display Position Adjustments Tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Black textured back cover, black metal base, black front
Dimensions (WxDxH) - with stand 69.81 cm x 20.94 cm x 41.09 cm
Weight 5.2 kg
Compliant Standards FCC Class B certified, UL, TUV, cUL, EN 61000-3-3, EN55024, DDC/CI, EN 60950-1:2006, EN61000-3-2:2006, EMC 2004/108/EC, LVD 2006/95/EC, EN55022:2006 Class B
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG 29WK500 29" 2560x10...
£266.66
