LG 32MP58HQ-P 31.5" 1920x1080 5ms VGA HDMI AH-IPS LED Mo...
LG 32MP58HQ-P 31.5" 1920x1080 5ms VGA HDMI AH-IPS LED Monitor
Key features
  • Vivid colors from any angle, LG IPS
  • Sleek Cut design
  • Protect your eyes and view in comfort
  • Offers improved color vision to color weakness
Product codes
The LG IPS Monitor ensures and awesome picture quality that provides clear images and vivid colors from any angle for your viewing pleasure.
The Sleek Cut design, the remarkable reduction of depth with body frame, adds sophisticated ambience for your place.
Flicker Safe and Reader mode help maximize visual comfort by protecting your eyes from harmful blue light and reducing the flicker level to almost zero.
Product Description LG 32MP58HQ-P - LED monitor - Full HD (1080p) - 31.5"
Device Type LED-backlit LCD monitor - 31.5"
Energy Class Class A
Energy Consumption per Year 52 kWh
Power Consumption (On mode) 36 W
Panel Type AH-IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.363 mm
Brightness 250 cd/m²
Contrast Ratio 1200:1 / 5000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA
Display Position Adjustments Tilt
Screen Coating 3H Hard Coating
Colour High-gloss piano lacquer black
Dimensions (WxDxH) - with stand 72.66 cm x 20.48 cm x 49.19 cm
Weight 6.5 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, UL, TUV, cUL, DDC/CI, RoHS, EPA 6.0, IEC 62087 Edition 2
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG 32MP58HQ-P 31.5" 19...
