32 Inch 4K UHD
Outstanding Ultra HD performance is assured by the specially designed 4K display, delivering accurate colors that remain consistent with four times the resolution of Full HD.
DCI-P3 95% Color Gamut
This monitor covers 95% of the DCI-P3 color space, the current standard utilized by the film industry, assuring an exceptionally wide range of available colors.
HDCP 2.2 Compatible
Connect with confidence: This LG 4K monitor is compatible with the latest HDCP 2.2 copy protection, so it will display video from 4K streaming services, game consoles and Ultra HD Blu-ray disc players.
AMD FreeSync Technology
LG's monitors with AMD FreeSync technology reduce the tearing and stuttering that occur between a graphic card’s frame rate and a monitor’s refresh rate. Thanks to FreeSync, gaming enthusiasts can experience seamless, fluid movement throughout any hi-res, heavy-duty game.
Dynamic Action Sync
Gamers can experience optimized, fast-pace gaming with Dynamic Action Sync. Dynamic Action Sync is a feature that minimizes input lag so the game play in RTS games is more responsive.
Black Stabilizer
Keep visibility even in dark scenes. LG's Black Stabilizer senses dark scenes and helps make it brighter so that you can find the enemies hiding and waiting to attack your player in the dark.
On-Screen Control
On-Screen Control puts a host of monitor settings into a handy window for quick, easy access. Volume, brightness, picture mode presets, Screen Split 2.0 and Dual Controller can be adjusted with just a few clicks of the mouse.
Screen Split
Customize your monitor layout for multitasking with the latest version of LG Screen Split. Resize and display multiple windows at once, with 14 options including four different picture-in-picture (PIP) choices.
Height Adjustable Display
Find your perfect viewing angle: The adjustable stand allows users to raise and lower the monitor as desired to provide the best possible view.
Product Description | LG 32UD59-B - LED monitor - 4K - 32" | Device Type | LED-backlit LCD monitor - 32" | Energy Class | Class A | Energy Consumption per Year | 58 kWh | Power Consumption (On mode) | 40 W | Adaptive-Sync Technology | AMD FreeSync | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | 4K 3840 x 2160 at 60 Hz | Pixel Pitch | 0.181 mm | Brightness | 300 cd/m² | Contrast Ratio | 3000:1 | Response Time | 4 ms (grey-to-grey) | Input Connectors | 2xHDMI, DisplayPort | Display Position Adjustments | Height, tilt | Screen Coating | Anti-glare, 3H Hard Coating | Colour | Matte black | Dimensions (WxDxH) - with stand | 72.81 cm x 23.68 cm x 45.82 cm | Weight | 7.1 kg | Environmental Standards | TCO Certified Displays 7 | Compliant Standards | FCC Class B certified, UL, CB, DDC/CI, KC, ERP, EPA 7.0 | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 32" |
Viewable Size | 31.5" |
Panel Type | VA |
Vertical Refresh Rate | 56 - 61 Hz |
Horizontal Refresh Rate | 30 - 135 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | HDCP, SUPER + Resolution, On-screen Digital Controls, blue light reduction, Flicker Safe, Smart Energy Saving technology, Dual Controller, Black Stabilizer, DAS Mode (Dynamic Action Sync), colour adjustment mode, DCI-P3 95% colour gamut |
Dimensions (WxDxH) | 72.81 cm x 23.68 cm x 45.82 cm - with stand |
Weight | 7.1 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 5 Watt |
Connectivity | |
Interfaces | 2 x HDMI , DisplayPort , Headphones |
Mechanical | |
Tilt Angle | -5/+20 |
Height Adjustment | 120 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Cables Included | 1 x HDMI cable , 1 x DisplayPort cable |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 50 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.5 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 72.81 cm - depth: 23.68 cm - height: 45.82 cm - weight: 7.1 kg , Without stand - width: 72.81 cm - depth: 4.99 cm - height: 42.46 cm - weight: 5.3 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 7 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
