LG 32UD59 32" 3840x2160 4ms HDMI DisplayPort LED Monitor
£547.00
Delivery:
Key features
  • DCI-P3 95% color gamut
  • HDCP 2.2 compatible
  • AMD FreeSync technology
  • Dynamic action sync
  • Black stabilizer
  • On-screen control
  • Screen split
  • Height adjustable display
Product codes
32 Inch 4K UHD
Outstanding Ultra HD performance is assured by the specially designed 4K display, delivering accurate colors that remain consistent with four times the resolution of Full HD.
DCI-P3 95% Color Gamut
This monitor covers 95% of the DCI-P3 color space, the current standard utilized by the film industry, assuring an exceptionally wide range of available colors.
HDCP 2.2 Compatible
Connect with confidence: This LG 4K monitor is compatible with the latest HDCP 2.2 copy protection, so it will display video from 4K streaming services, game consoles and Ultra HD Blu-ray disc players.
AMD FreeSync Technology
LG's monitors with AMD FreeSync technology reduce the tearing and stuttering that occur between a graphic card’s frame rate and a monitor’s refresh rate. Thanks to FreeSync, gaming enthusiasts can experience seamless, fluid movement throughout any hi-res, heavy-duty game.
Dynamic Action Sync
Gamers can experience optimized, fast-pace gaming with Dynamic Action Sync. Dynamic Action Sync is a feature that minimizes input lag so the game play in RTS games is more responsive.
Black Stabilizer
Keep visibility even in dark scenes. LG's Black Stabilizer senses dark scenes and helps make it brighter so that you can find the enemies hiding and waiting to attack your player in the dark.
On-Screen Control
On-Screen Control puts a host of monitor settings into a handy window for quick, easy access. Volume, brightness, picture mode presets, Screen Split 2.0 and Dual Controller can be adjusted with just a few clicks of the mouse.
Screen Split
Customize your monitor layout for multitasking with the latest version of LG Screen Split. Resize and display multiple windows at once, with 14 options including four different picture-in-picture (PIP) choices.
Height Adjustable Display
Find your perfect viewing angle: The adjustable stand allows users to raise and lower the monitor as desired to provide the best possible view.
Product Description LG 32UD59-B - LED monitor - 4K - 32"
Device Type LED-backlit LCD monitor - 32"
Energy Class Class A
Energy Consumption per Year 58 kWh
Power Consumption (On mode) 40 W
Adaptive-Sync Technology AMD FreeSync
Panel Type VA
Aspect Ratio 16:9
Native Resolution 4K 3840 x 2160 at 60 Hz
Pixel Pitch 0.181 mm
Brightness 300 cd/m²
Contrast Ratio 3000:1
Response Time 4 ms (grey-to-grey)
Input Connectors 2xHDMI, DisplayPort
Display Position Adjustments Height, tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Matte black
Dimensions (WxDxH) - with stand 72.81 cm x 23.68 cm x 45.82 cm
Weight 7.1 kg
Compliant Standards FCC Class B certified, UL, CB, DDC/CI, KC, ERP, EPA 7.0
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG 32UD59 32" 3840x216...
£547.00
