Outstanding Color Accuracy and Wide Viewing Angle
LG IPS display supports a wide color spectrum, 99% of sRGB color gamut, and offers outstanding color and brightness with the support of VESA Display HDR™400.
Fully Use Your Desk
The compact design takes up very little desk surface and also contributes to easier installation.
Easy Connectivity
USB Type-C™ port allows from display and data transferring to connected device charging(up to 65W), enabling support for your laptop all at the same time over a single cable. It helps to boost efficiency and productivity by making a clutter-free workspace.
Incredible Speed to Victory
1ms MBR helps smooth gameplay, reducing blur and ghosting. Dynamic and fast-paced objects amidst all the action can give gamers a competitive edge.
Product Description | LG UltraWide 34WQ680-W - LED monitor - 34" - HDR | Device Type | LED-backlit LCD monitor - 34" | Energy Class | Class G | Adaptive-Sync Technology | AMD FreeSync | Features | USB PD 65 Watt | Panel Type | IPS | Aspect Ratio | 21:9 | Native Resolution | WFHD 2560 x 1080 at 100 Hz | Brightness | 400 cd/m² | Contrast Ratio | 1000:1 | HDR Capable | HDR10 / DisplayHDR 400 | Response Time | 5 ms (grey-to-grey), 1 ms (MBR) | Colour Support | 16.7 million colours | Colour Gamut | 99% sRGB (CIE 1931) | Input Connectors | HDMI, DisplayPort, USB-C | Display Position Adjustments | Height, swivel, tilt, extend, retract | Voltage | AC 100-240 V (50 - 60 Hz) | Dimensions (WxDxH) - with stand | 81.65 cm x 40.51 cm x 62.2 cm | Weight | 9.9 kg | Manufacturer Warranty | 2-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Energy Class (HDR) | Class G |
Diagonal Size | 34" |
USB Power Delivery | 65 Watt |
Panel Type | IPS |
HDR Format | HDR10 |
HDR Certification | DisplayHDR 400 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | ErgoStand, Crosshair Display, Flicker Safe, Reader Mode, Motion Blur Reduction, Factory Calibration, MaxxAudio, Smart Energy Saving technology, Black Stabilizer, DAS Mode (Dynamic Action Sync), Color Weakness Mode, Super Resolution+, 3-side virtually borderless display, HDR Effect, auto input switch, one click mount |
Dimensions (WxDxH) | 81.65 cm x 40.51 cm x 62.2 cm - with stand |
Weight | 9.9 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 7 Watt |
Connectivity | |
Interfaces | DisplayPort 1.4 , HDMI , USB-C with Power Delivery (power up to 65W) , Headphones (mini-jack) |
Mechanical | |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), C-clamp |
Cables Included | 1 x USB-C cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 100-240 V (50 - 60 Hz) |
Power Consumption SDR (On mode) | 32 kWh/1000h |
Power Consumption HDR (On mode) | 42 kWh/1000h |
Power Consumption (Typical) | 35 Watt |
Power Consumption (Max) | 110 Watt |
Power Consumption Sleep | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Software / System Requirements | |
Included Software | Dual Controller Software, LG On-Screen Control |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 81.65 cm - depth: 40.51 cm - height: 62.2 cm - weight: 9.9 kg , Without stand - width: 81.65 cm - depth: 4.55 cm - height: 36.53 cm - weight: 6 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 91.4 cm |
Shipping Depth | 24.5 cm |
Shipping Height | 48.3 cm |
Shipping Weight | 12.9 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 2 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
