LG 34UM69G 34" 2560x1080 1ms HDMI DisplayPort USB-C Ultr...
LG 34UM69G 34" 2560x1080 1ms HDMI DisplayPort USB-C UltraWide IPS LED Monitor
£500.00
Delivery:
Key features
  • Ultra-wide gaming with 1ms Motion Blur Reduction
  • AMD FreeSync technology
  • Dynamic Action Sync
  • Black Stabilizer
  • Game mode
  • V-line stand
  • Diagonal Size: 34in
  • Max Resolution: 2560 x 1080
  • Response Time: 14ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, USB-C
Product codes
UltraWide® Gaming with 1ms Motion Blur Reduction
The Full HD UltraWide 21:9 aspect ratio makes games more immersive. 1ms Motion Blur Reduction allows gamers to enjoy the precision and accuracy needed to play at a very high level. With a response time that is virtually 1ms, blurring and ghosting are reduced to make the action smoother and gaming more precise.
AMD FreeSync™* Technology
FreeSync reduces the tearing and stuttering that occur between a graphic card’s frame rate and a monitor’s refresh rate. With FreeSync, gamers can experience seamless, fluid movement throughout games without the need to upgrade your graphics card.
Dynamic Action Sync
Gamers can experience optimized, fast-pace gaming with Dynamic Action Sync. Dynamic Action Sync is a feature that minimizes input lag so the game play in RTS games is more responsive.
Black Stabilizer
Keep visibility even in dark scenes. LG's Black Stabilizer senses dark scenes and helps make it brighter so that you can find the enemies hiding and waiting to attack your player in the dark.
Game Mode
Set your game mode to optimize and customize your gaming conditions. There are 3 gamer modes, 2 First-Person-Shooter modes and even a RTS pre-set mode so you can choose the best mode for you and the game you're playing.
V-Line Stand
The sleek design of this gaming monitor is accentuated by red color accents on the V-shape stand. This monitor will feel right at home as part of any gamer's desktop setup.
ENERGY STAR® Qualified
Earning the ENERGY STAR® means a product meets stringent energy efficiency requirements set by the US Environmental Protection Agency. ENERGY STAR certified televisions are on average, 25 percent more energy efficient than conventional models, saving energy in all usage modes: sleep, idle, and on.
Product Description LG 34UM69G - LED monitor - 34"
Device Type LED-backlit LCD monitor - 34"
Energy Class Class A
Energy Consumption per Year 57 kWh
Power Consumption (On mode) 39 W
Adaptive-Sync Technology AMD FreeSync
Panel Type IPS
Aspect Ratio 21:9
Native Resolution 2560 x 1080 at 75 Hz
Pixel Pitch 0.312 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, DisplayPort, USB-C
Screen Coating Anti-glare, 3H Hard Coating
Colour High glossy black, Pearl Red
Dimensions (WxDxH) - with stand 82.85 cm x 27.97 cm x 46.53 cm
Weight 8.5 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards FCC Class B certified, UL, TUV, cUL, CCC, DDC/CI, ERP, EPA 7.0
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG 34UM69G 34" 2560x10...
£500.00
