LG 34WK500 34" 2560x1080 5ms HDMI UltraWide IPS LED Monitor
£451.28
19 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Play games with optimized settings
  • Clearer, smoother image
  • Versatile elegance
Product codes
21:9 UltraWide® Display
The UltraWide 21:9 aspect ratio makes movies and games more immersive than ever. Need to get some work done, too? All of that UltraWide real estate makes it easy to view multiple documents at the same time, so you don't need to flip back and forth between them.
sRGB 99%
sRGB is the standard color space of ideal color reproduction. So, with over 99% coverage of the sRGB spectrum, this LG monitor is a great solution for professional photographers, graphic designers or anyone looking for highly accurate color.
On-Screen Control
On-Screen Control puts a host of essential monitor settings into a handy window for quick, easy access. Volume, brightness, picture mode presets, Screen Split 2.0 and Dual Controller and more can now be adjusted with just a few clicks of the mouse, instead of hard buttons on the monitor.
AMD FreeSync™
With FreeSync*, gamers can experience seamless, fluid movement throughout hi-res, fast-paced games. FreeSync virtually eliminates screen tearing and stuttering.
Advanced Gaming Features
Serious gaming features for serious gamers. Quickly optimize monitor settings to activate Black Stabilizer to reveal superior detail in dark scenes while the Dynamic Action Sync feature assures smooth, fluid gaming action.
Sleek Design
The sleek design of LG premium monitors is accentuated by the new ArcLine stand. The smooth curve of the base provides stability, assuring dependable performance with a touch of elegance
Product Description LG 34WK500-P - LED monitor - 34"
Device Type LED-backlit LCD monitor - 34"
Energy Class Class A
Power Consumption (On mode) 37 W
Adaptive-Sync Technology AMD FreeSync
Panel Type AH-IPS
Aspect Ratio 21:9
Native Resolution UWFHD 2560 x 1080 at 75 Hz
Pixel Pitch 0.3108 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors 2xHDMI
Display Position Adjustments Tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Black textured back cover, black metal base, black front
Dimensions (WxDxH) - with stand 82.9 cm x 20.9 cm x 46.07 cm
Weight 6.9 kg
Compliant Standards FCC Class B certified, UL, TUV, cUL, EN 61000-3-3, EN55024, DDC/CI, EN 60950-1:2006, EN61000-3-2:2006, EMC 2004/108/EC, LVD 2006/95/EC, EN55022:2006 Class B
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG 34WK500 34" 2560x10...
£451.28
