LG 34WK650 34" 2560x1080 5ms HDMI DisplayPort UltraWide...
£382.90
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • HDR 10
  • HDR Effect
  • Virtually borderless design
  • UltraWide display
  • On-screen control
  • Advanced gaming features
  • Sleek design
  • Diagonal Size: 34in
  • Max Resolution: 2560 x 1080
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI
Product codes
HDR 10
To more fully realize content creators’ vision, this monitor is compatible with industry-standard HDR10 high dynamic range, supporting specific levels of color and brightness that exceed the capabilities of ordinary monitors.
HDR Effect
The HDR Effect helps transform non-HDR content into high quality video that looks like HDR through its picture quality algorithm.
IPS with sRGB 99% (Typ.)
This monitor, with 99% coverage of the sRGB spectrum, is a great solution for photographers, graphic designers or anyone looking for highly accurate color.
Virtually Borderless Design
The ultra-thin bezel on three sides of this streamlined display offers a virtually borderless visual experience, without distraction from the precise, gorgeous image. A sleek addition to any desktop.
21:9 UltraWide® Display
The UltraWide 21:9 aspect ratio makes movies and games more immersive than ever. Need to get some work done, too? All of that UltraWide real estate makes it easy to view multiple documents at the same time, so you don't need to flip back and forth between them.
On-Screen Control
On-Screen Control puts a host of essential monitor settings into a handy window for quick, easy access. Volume, brightness, picture mode presets, Screen Split 2.0 and Dual Controller and more can now be adjusted with just a few clicks of the mouse, instead of hard buttons on the monitor.
AMD FreeSync™
With FreeSync*, gamers can experience seamless, fluid movement throughout hi-res, fast-paced games. FreeSync virtually eliminates screen tearing and stuttering.
Advanced Gaming Features
Serious gaming features for serious gamers. Quickly optimize monitor settings to activate Black Stabilizer to reveal superior detail in dark scenes while the Dynamic Action Sync feature assures smooth, fluid gaming action.
Sleek Design
The sleek design of LG premium monitors is accentuated by the ArcLine stand. The smooth curve of the base provides stability, assuring dependable performance with a touch of elegance.
  • 34" 21:9 WFHD (2560 x 1080) IPS Display
  • HDR 10
  • sRGB 99%
  • AMD FreeSync™ Technology
  • 3-Side Virtually Borderless Design
  • Tilt / Height Adjustable Stand
Product Description LG 34WK650-W - LED monitor - 34"
Device Type LED-backlit LCD monitor - 34"
Energy Class Class A
Energy Consumption per Year 55 kWh
Power Consumption (On mode) 38 W
Adaptive-Sync Technology AMD FreeSync
Panel Type AH-IPS
Aspect Ratio 21:9
Native Resolution UWFHD 2560 x 1080 at 75 Hz
Pixel Pitch 0.315 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors 2xHDMI, DisplayPort
Display Position Adjustments Height, tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Black front, matte silver base, textured white back
Dimensions (WxDxH) - with stand 82.56 cm x 23 cm x 46.07 cm
Weight 7.6 kg
Compliant Standards FCC Class B certified, UL, TUV, cUL, EN 61000-3-3, EN55024, DDC/CI, EN 60950-1:2006, EN61000-3-2:2006, EMC 2004/108/EC, LVD 2006/95/EC, EN55022:2006 Class B, EPA 7.0
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG 34WK650 34" 2560x10...
£382.90
