The pinnacle of gaming monitors. Complete your battle station with a premium LG UltraGear gaming monitor. Built for gamers, it delivers the latest hardware, specs, ergonomics, sleek design and sensory experience. With gaming-focused features like NVIDIA G-SYNC compatibility, 1ms GTG response times, pro-level customization and a fast, vivid IPS panel, you're sure to gain an added edge.
Product Description | LG UltraGear 38GN950-B - LED monitor - curved - 37.5" - HDR | Device Type | LED-backlit LCD monitor - 37.5" | Energy Class | Class G | Power Consumption (On mode) | 41.9 W | Curved Screen | Yes | Adaptive-Sync Technology | AMD FreeSync Premium Pro, NVIDIA G-SYNC Compatible | Features | USB 3.0 hub | Panel Type | Nano IPS | Aspect Ratio | 21:9 | Native Resolution | UWQHD+ 3840 x 1600 at 144 Hz | Pixel Pitch | 0.2291 mm | Brightness | 450 cd/m² | Contrast Ratio | 1000:1 | HDR Capable | HDR10 / DisplayHDR 600 | Response Time | 1 ms (grey-to-grey) | Colour Support | 1.07 billion colours | Colour Gamut | 98% DCI-P3 (CIE 1976) | Input Connectors | 2xHDMI, DisplayPort | Display Position Adjustments | Height, tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) - with stand | 89.64 cm x 31.22 cm x 47.84 cm | Weight | 9.2 kg | Compliant Standards | DisplayPort 1.4 |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Energy Class (HDR) | Class G |
Diagonal Size | 37.5" |
Built-in Devices | USB 3.0 hub |
HDR Format | HDR10 |
HDR Certification | DisplayHDR 600 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | On-screen Digital Controls, Black Stretch technology, Crosshair Display, Flicker Safe, Reader Mode, Wide Colour Gamut, Color Calibrated, DAS Mode (Dynamic Action Sync), Sphere Lighting 2.0, Sound Sync mode, Video Sync mode, overclocked 160 Hz |
Dimensions (WxDxH) | 89.64 cm x 31.22 cm x 47.84 cm - with stand |
Weight | 9.2 kg |
Connectivity | |
Interfaces | 2 x HDMI , DisplayPort , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream , Headphones |
Mechanical | |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Maxx Audio support |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 41.9 kWh/1000h |
Power Consumption HDR (On mode) | 106 kWh/1000h |
Power Consumption (Typical) | 70 Watt |
Power Consumption Sleep | 0.5 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Software / System Requirements | |
Included Software | LG UltraGear Control Center |
Dimensions & Weight | |
Dimensions & Weight Details | With stand (lowest position) - width: 89.64 cm - depth: 31.22 cm - height: 47.84 cm - weight: 9.2 kg , With stand (highest position) - width: 89.64 cm - depth: 31.22 cm - height: 58.84 cm - weight: 9.2 kg , Without stand - width: 89.64 cm - depth: 11.13 cm - height: 39.44 cm - weight: 7 kg |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
