LG 38WK95C 38" 3840x1600 5ms HDMI DisplayPort USB-C Ultr...
LG 38WK95C 38" 3840x1600 5ms HDMI DisplayPort USB-C UltraWide Curved IPS LED Monitor
£1,162.39
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
  • Diagonal Size: 37.5in
  • Max Resolution: 3840 x 1600
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, USB-C
Product codes
Walk into The New World of HDR
HDR is now considered the industry standard for high-quality pictures in display devices. HDR 10 supported monitors can display HDR-coded games with the latest consoles and HDR videos from major streaming "Video On Demand" Services.
HDR 10 - Detailed Contrast
HDR-compatible monitors display brighter whites and blacker blacks compared to conventional displays. HDR renders dark and bright areas of an image, enhancing details whcih where more difficult to see under the old standards.
HDR Effect to SDR Content
HDR Effect feature uses a picture quality algorithm to convert non-HDR content into high quality video on par with vivid HDR visuals.
True Colours and Wider View
LG IPS monitors display impeccable colour accuracy. With a wider viewing angle, the IPS display boasts 99% coverage of the sRGB colour spectrum.
More Space for Multi-Tasking
The UltraWide™ QHD+(3840x1600) resolution is equivalent to three times that of a 16:9 Full HD (1920x1080) whilst providing more space than a 34-inch 21:9 QHD real estate, making it ideal for viewing and processing more information.
Immersive Visual Experience
This streamlined display features a slim bezel on three sides and Rich Bass providing an immersive Audio and Visual experience.
Easy Control and Connectivity
With USB Type-C™, which offering reliable compatibility with both Laptops and MacBook. With USB Type-C™, you can connect your display, transfer data and charge your laptop or a mobile device, up to 60W over a single cable.
Versatile Elegance
The curved base enhances stability for dependable performance. The base can be adjusted to change the tilt, height and angle of the monitor for a more comfortable viewing experience.
Product Description LG 38WK95C-W - LED monitor - curved - 37.5"
Device Type LED-backlit LCD monitor - 37.5"
Energy Class Class B
Energy Consumption per Year 76 kWh
Power Consumption (On mode) 52 W
Curved Screen Yes
Adaptive-Sync Technology AMD FreeSync
Features USB 3.0 hub
Panel Type AH-IPS
Aspect Ratio 21:9
Native Resolution UWQHD+ 3840 x 1600 at 75 Hz
Pixel Pitch 0.229 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms (grey-to-grey)
Colour Support 1.073 billion colours (8-bit)
Input Connectors 2xHDMI, DisplayPort, USB-C
Display Position Adjustments Height, tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Glossy white back cover, black front, silver frame and base
Dimensions (WxDxH) - with stand 89.72 cm x 23.04 cm x 46.62 cm
Weight 9.3 kg
Compliant Standards FCC Class B certified, UL, TUV, EN 61000-3-3, EN55024, DDC/CI, EN 61000-3-2:2006, EN 60950-1:2006, EMC 2004/108/EC, LVD 2006/95/EC, EN55022:2006 Class B, EPA 7.0, HDCP 2.2
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG 38WK95C 38" 3840x16...
£1,162.39
