43" LG Smart TV with webOS
Key Features
Quad Core Processor
Active HDR
Full HD Resolution
Virtual Surround Plus
2 Pole Stand
Smart TV webOS
Product Description | LG 43LK5900 43" LED TV | Product Type | LED-backlit LCD TV - Smart TV | Diagonal Class | 43" | Platform | LG ThinQ AI, webOS 4.0 | Resolution | 1920 x 1080 | Display Format | 1080p (Full HD) | HDR Technology | HDR 10, Hybrid Log-Gamma (HLG), Active HDR | Motion Enhancement Technology | 1000 Hz Picture Mastering Index, 50 Hz Native Refresh Rate, TruMotion 100 | Video Interface | Component, composite, HDMI | HDMI Ports Qty | 2 ports | Connectivity | Wi-Fi, LAN | LCD Backlight Technology | LED backlight - direct-lit LED | Image Aspect Ratio | 16:9 | TV Tuner | 1x analogue, 1x digital | Digital TV Tuner | DVB-C, DVB-S2, DVB-T2 | Internet Streaming Services | HbbTV, Magic Link | Picture Enhancements | Dynamic Colour Enhancer, Noise Reduction | Speaker System | 2 speakers | Sound Effects | Virtual Surround Plus | USB | Yes | Remote Control | Standard remote | Voltage | AC 120/230 V (50/60 Hz) | Energy Class | Class A+ | Power Consumption (On mode) | 55 W | Power Consumption Stand by | 0.5 Watt | Energy Consumption per Year | 76 kWh | Dimensions (WxDxH) - without stand | 97.7 cm x 8.1 cm x 57.5 cm | Weight | 8 kg |
General | |
HDR Capable | Yes |
TV Tuner Presence | Yes |
Sensors | Illuminance green sensor |
Dimensions | Without stand |
Width | 97.7 cm |
Depth | 8.1 cm |
Height | 57.5 cm |
Weight | 8 kg |
Display | |
Display Menu Language | Multilingual |
Features | Time-shift, Quad-Core processor, text-to-speech function, My Channel, Magic Zoom |
Stands & Mounts | |
Stand | Included |
Stand Design | Tabletop |
VESA Mounting Interface | 200 x 200 mm |
TV Tuner | |
Conditional Access | Common Interface Plus (CI+) slot |
Digital TV Tuner | |
HDTV Tuner | Yes |
Video Features | |
Teletext | Yes |
Teletext Memory | 2000 pages |
Electronic Programme Guide | Digital EPG |
Media Player | |
Supported Video Formats | HEVC, VP9 |
Supported Audio Formats | MP3, WMA, PCM, AC3, AAC, HE-AAC, E-AC3, DTS, MP2 |
USB Port | Yes |
USB Ports Qty | 1 |
Remote Control | |
Type | Standard remote |
Audio System | |
Surround Mode | Yes |
Output Power / Total | 10 Watt |
Features | Quick Disconnect, Audio Return Channel (ARC), Clear Voice III technology |
Speakers | 2 x speaker - built-in - 5 Watt |
Network & Internet Multimedia | |
Functionality | Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback |
LAN Protocol | Ethernet |
Wi-Fi Protocol | 802.11ac |
Connect & Share | Wi-Fi Miracast |
Supported Consumer Electronics Control (CEC) | Simplink |
DLNA | Yes |
Connections | |
Connector Type | HDMI - side , HDMI - rear , USB - side , Composite video / component video input - rear , Network - rear , Digital audio output (optical) - rear |
Miscellaneous | |
Included Accessories | Batteries |
Power | |
Power Device | Power supply |
Nominal Voltage | AC 120/230 V (50/60 Hz) |
Dimensions & Weight Details | |
Dimensions & Weight Details | Panel without stand - 97.7 cm x 8.1 cm x 57.5 cm x 8 kg , Panel with stand - 97.7 cm x 18.7 cm x 61.5 cm x 8.1 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 106 cm |
Depth (Shipping) | 18.7 cm |
Height (Shipping) | 61.5 cm |
Weight (Shipping) | 10.5 kg |
