LG 43" UK6300 4K Ultra HD with HDR Smart LED TV
CASHBACK
Sorry but this product has been discontinued.
View used stock
Select:
  • 43"
Key features
  • LG UHD meets Artificial Intelligence
  • Breathtaking clarity
  • Strengthen the core
  • Pumped up resolution and color
  • The Ultra Surround sound
  • Screen Size: 43in
  • Screen Resolution: 4K UHD (2160p)
  • Smart: Smart TV
  • HDMI Inputs: 3
  • Interface: Component, Composite, HDMI
Product codes
43" LG ULTRA HD 4K TV
Key Features
IPS 4K Display
Active HDR
True Colour Accuracy
ThinQ AI
Ultra Surround
A New Standard of Definition.
A new depth of detail. ULTRA HD 4K resolution is four times that of Full HD producing brilliant clarity and vivid details that amaze, even when viewed up close. This level of detail is well suited to modern home entertainment, sports and gaming; the resulting images will redefine your viewing experience.
A vibrant and vivid picture from any angle
Our latest Ultra HD innovation is built into the unique IPS 4K panel meaning your entertainment is viewable from any angle without distortion.
More power to process
To support the advanced picture processing required for bright, sharp 4K images there are 4 cores of processing power available at the heart of this LG TV. A fast and powerful brain to make sure you have the best possible picture.
The Ultimate HDR 4K Picture
This advanced HDR technology can adapt to a variety of HDR formats and provides scene by scene image mastering, delivering pinpoint picture reproduction. Active HDR is better HDR.
Multi-channel bringing encapsulating sound effect
Great television deserves great audio. This sound technology creates virtual multi channels which produce the ultra surround effect.
Masterfully modern design.
A stylish frame is wrapped around your television Complimented by an elegant sweeping stand. This sleek design adds a touch of real class to any living room.
Experience 4K Ultra HD on BT TV
With up to four times the detail of High Definition, 4K Ultra HD makes you feel like you’re right in the heart of the action.
BT Sport in 4K Ultra HD has to be seen to be believed, and the only place to experience it is BT TV. We bring you the UEFA Champions League, Premier League, UEFA Europa League and the Emirates FA Cup as you’ve never seen them before.
All of the 4K Ultra HD TVs we sell here on BT Shop are guaranteed to work with your BT TV service to deliver amazing 4K content. BT Sport in 4K Ultra HD and our YouView Ultra HD box is included with the Max TV package, which is available to customers with BT Infinity broadband. The only other thing you’ll need is this 4K Ultra HD TV.
If you don't already have BT TV, or haven't upgraded to receive BT Sport in 4K Ultra HD, you'll need to head over to bt.com now to order these services:
BT Ultra HD
Promotions
Receive £100 Cashback when you buy this TV & BT Broadband
Buy a qualifying TV from BT Shop, and sign up for broadband with BT and we'll give you £100 cashback on your purchase. Click here for full details.
Product Description LG 43UK6300 43" LED TV - 4K
Product Type LED-backlit LCD TV - Smart TV
Diagonal Class 43"
Platform LG ThinQ AI, webOS 4.0
Resolution 3840 x 2160
Display Format 4K UHD (2160p)
HDR Technology HDR 10, Hybrid Log-Gamma (HLG), Active HDR
Frame Rate & Enhancement Technology 50 Hz Native Refresh Rate, 1600 Picture Mastering Index, TruMotion 100
Video Interface Component, composite, HDMI
HDMI Ports Qty 3 ports
Connectivity Wi-Fi, LAN, Bluetooth
Technology IPS
LCD Backlight Technology LED backlight - direct-lit LED
Image Aspect Ratio 16:9
TV Tuner 1x analogue, 1x digital
Digital TV Tuner DVB-C, DVB-S2, DVB-T2
Internet Streaming Services HbbTV, Magic Link
Picture Enhancements 4K Upscaling, Dynamic Colour Enhancer, Noise Reduction, True Colour Accuracy, Wide Colour Gamut
Speaker System 2 speakers
Sound Effects ULTRA Surround
USB 2 ports
Remote Control Standard remote
Voltage AC 120/230 V (50/60 Hz)
Energy Class Class A
Power Consumption (On mode) 71 W
Power Consumption Stand by 0.5 Watt
Energy Consumption per Year 98 kWh
Dimensions (WxDxH) - without stand 97.7 cm x 8.1 cm x 57.5 cm
Weight 8.3 kg
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been repaired under warranty by the manufacturer
Ref: DJ0H 040164
£253.39
product
Ref: DJ0H 040164
Accessories
Packaging
Functional
Software
Manuals
£253.39
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG 43" UK6300 4K Ultra...
