LG 43UD79-B 43" 3840x2160 5ms HDMI DisplayPort IPS LED M...
LG 43UD79-B 43" 3840x2160 5ms HDMI DisplayPort IPS LED Monitor
£665.60
Delivery:
Standard: 1-3 working days
Key features
  • 43" Class 4K UHD IPS display
  • HDCP 2.2 compatible
  • USB Type-C (DP Alt mode)
  • 4x HDMI inputs
  • Adjust display settings with remote
  • Screen split
  • 10 watt speakers with rich bass
  • Diagonal Size: 42.51in
  • Max Resolution: 3840 x 2160
  • Response Time: 8ms
  • Interfaces: DisplayPort, HDMI
  • Stock Status: In Stock
Product codes
The 43UD79-B, this 42.5-inch display has a native UHD resolution of 3840 x 2160 with a conventional refresh rate of 60Hz. It features an IPS panel with a non-glare coating, a peak brightness of 350 cd/m2, a contrast ratio of up to 1000:1, and an 8ms gray-to-gray (GTG) response time. The viewing angles are wide at 178°/178°, which is typical for an IPS display. Although support for 1.07 billion colors is claimed, the lack of an explicit mention of a 10-bit panel leads us to believe that this is an 8-bit panel using A-FRC to achieve a 10-bit color depth. On the plus side, this model will ship color calibrated from the factory.
Product Description LG 43UD79-B - LED monitor - 4K - 42.51"
Device Type LED-backlit LCD monitor - 42.51"
Energy Class Class A
Energy Consumption per Year 98 kWh
Power Consumption (On mode) 67 W
Features USB 3.0 hub
Panel Type IPS
Native Resolution 4K 3840 x 2160
Pixel Pitch 0.2451 mm
Brightness 350 cd/m²
Contrast Ratio 1000:1
Response Time 8 ms (grey-to-grey)
Colour Support 1.06 billion colours
Input Connectors 4xHDMI, DisplayPort
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG 43UD79-B 43" 3840x2...
£665.60
