The OLED on everyone's list.
True darkness brings the light.
LG OLED pixels light up independently with no backlight to dull their glow. Now, dark areas are perfectly black with no light bleed or halo effect. Envision a crisp picture with unmatched depth.
Beauty meets brains.
The brains behind the beauty. Following deep learning advancements, LG's a7 Gen 5 AI Processor uses Foreground and Background Enhancing to maximise the field of depth for outstandingly lifelike image quality.
Dazzling darks, luminous lights.
With no backlight to dull their impact,self-lit pixels achieve the deepest blacks for crisp contrast in every light. Visuals are more defined, so you can make out subtle details your eyes usually miss.
Punchier picture quality.
Dynamic Tone Mapping uses the a7 Gen 5 AI Processor to detect what's in the frame and apply the optimal tone curve. The result is natural HDR, deep contrast, and intricate detail.
Hear them coming in on you.
The a7 Gen 5 AI Processor up-mixes 2-channel audio into virtual 5.1.2 channel sound. Feel the action and chaos around you as you venture deeper into your game world.
1. Buy a qualifying TV from BT Shop. The TV MUST be purchased before you order BT Broadband.
2. You will receive an exclusive code in your order confirmation email from BT Shop with a link to order your Broadband package
3. Place your Broadband package order on BT.com via your unique link
4. Receive £100 cashback!
Click here for full Terms and Conditions.
Product Description | LG OLED65A26LA A2 Series - 65" OLED TV - 4K | Product Type | OLED TV - Smart TV | Diagonal Class | 65" | Platform | webOS, LG ThinQ AI | Resolution | 3840 x 2160 | Display Format | 4K UHD (2160p) | HDR Format | HDR10, Dolby Vision | HDR Technology | Hybrid Log-Gamma (HLG), HDR 10 Pro, Cinema HDR, Dolby Vision IQ | Frame Rate & Enhancement Technology | 60 Hz Refresh Rate | Video Interface | HDMI | HDMI Ports Qty | 3 ports | Connectivity | Wi-Fi, LAN, Bluetooth | Image Aspect Ratio | 16:9 | TV Tuner | 1x analogue, 1x digital | Digital TV Tuner | DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2 | Internet Streaming Services | Netflix, Voice Search, Home Dashboard, Prime Video, Disney+, Sports Alert, Apple TV+, LG Channels, HBO Max | Picture Enhancements | PerfectColor, Auto Calibration, Infinite Contrast, Perfect Black, Billion Rich Colours, Dynamic Tone Mapping, Pixel Dimming, AI Brightness, AI Picture Pro, Game Optimiser | Speaker System | 2 channel | Platform | Apple HomeKit, Google Home | Intelligent Assistant | Google Assistant, Alexa (not available for some languages and countries) | USB | 2 ports | Included Accessories | LG MR22GA remote control | Voltage | AC 100-240 V (50/60 Hz) | Energy Class | Class F | Power Consumption Stand by | 0.5 Watt | Dimensions (WxDxH) - without stand | 144.9 cm x 4.59 cm x 83.2 cm | Weight | 17.1 kg | Manufacturer Warranty | 1-year warranty |
General | |
Energy Class (HDR) | Class G |
Power Consumption SDR (On mode) | 90 kWh/1000h |
Power Consumption HDR (On mode) | 181 kWh/1000h |
Series | A2 Series |
Model Year | 2022 |
HDR Capable | Yes |
Video Processor | ?7 Gen 5 AI 4K |
TV Tuner Presence | Yes |
Sensors | Illuminance green sensor |
Modes | Game mode, Eco mode, Expert mode, Football Mode, Cinema mode, hotel mode, Standard mode, Vivid mode, Auto Low Latency Mode (ALLM), Filmmaker Mode, HGIG Mode, Art Gallery |
Dimensions | Without stand |
Width | 144.9 cm |
Depth | 4.59 cm |
Height | 83.2 cm |
Weight | 17.1 kg |
Display | |
Response Time | 0.1 ms |
Display Menu Language | Multilingual |
Features | Audio Description (AD), time-shift, Low Blue Light Technology, Wireless TV On, Flicker free technology, 10-bit support, Virtual Reality (360 VR) function, STT (Speech To Text), Time Machine, ThinQ AI, Apple AirPlay 2 support, AI Upscaling, AI Brightness Control, AI Genre Selection, Digital Recording, Family Settings, Block access to harmful site, DIAL, Quick Access, Bluetooth Low Energy On, Related Content Search, Universal Control |
Stands & Mounts | |
Stand | Included |
Stand Design | Tabletop |
Flat Panel Mount Interface | 300 x 200 mm |
VESA Compatibility | Yes |
TV Tuner | |
Conditional Access | Common Interface Plus (CI+) slot |
Digital TV Tuner | |
HDTV Tuner | Yes |
Video Features | |
Teletext | Yes |
Teletext Memory | 2000 pages |
Electronic Programme Guide | 8-day EPG |
Media Player | |
Supported Video Formats | HEVC, VP9, AV1 |
Supported Audio Formats | MP3, WMA, PCM, AC3, AAC, HE-AAC, E-AC3, MP2, AC4 |
USB Port | Yes |
USB Ports Qty | 2 |
Configuration | Quad-Core |
Operating System | webOS 2.0 |
Remote Control | |
Type | Remote control |
Remote Control Model | LG MR22GA |
Battery Form Factor | AA type |
Battery Included | Yes |
Battery Included Qty | 2 |
Battery Required Qty | 2 |
Features | Magic remote |
Audio System | |
Digital Audio Format | Dolby Atmos |
Surround Mode | Yes |
Output Power / Total | 20 Watt |
Features | Down-firing Speaker, Voice Control, text to speech function, apt-X technology, Simultaneous Audio, LG Sound Sync, Enhanced Audio Return Channel (eARC), Apple AirPlay 2 support, AI Acoustic Tuning, WiSA speakers, AI Sound Pro, Bluetooth Surround ready, Clear Voice Pro technology, AI Home, AI Recommendation, Intelligent Edit |
Network & Internet Multimedia | |
Functionality | WEB browsing, Internet video playback |
LAN Protocol | Ethernet |
Wi-Fi Protocol | 802.11ac |
Bluetooth Version | Bluetooth 5.0 |
Connect & Share | Screen Share, Sound Share |
Supported Consumer Electronics Control (CEC) | Simplink |
Application Store | LG App Store |
Connections | |
Connector Type | HDMI - rear , 2 x HDMI - side , Digital audio output (optical) - rear , Network - rear , USB - side , USB - rear |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Miscellaneous | |
Compliant Standards | HGiG |
Power | |
Power Device | Power supply |
Input Voltage | AC 100-240 V (50/60 Hz) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Dimensions & Weight Details | |
Dimensions & Weight Details | Panel without stand - 144.9 cm x 4.59 cm x 83.2 cm x 17.1 kg , Panel with stand - 144.9 cm x 23.5 cm x 89.6 cm , Stand - 105.7 cm x 23.5 cm |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 160 cm |
Depth (Shipping) | 17.2 cm |
Height (Shipping) | 95 cm |
Weight (Shipping) | 24.4 kg |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
