LG Electronics 22MB67PY 22" 1680x1080 5ms DVI VGA LED Mo...
LG Electronics 22MB67PY 22" 1680x1080 5ms DVI VGA LED Monitor
Key features
  • Motion energy saver
  • Ergonomic design
  • Reader mode
  • Flicker safe
  • Smart Energy Saving
Product codes
The screen turn off/on automatically when the sensor detects you seat or leave in front of monitor.
Pivot & Height, Swivel and Tilt Adjustments support various work enviornment and office app template.
Reader Mode provides optimal reading conditions by reducing harmful blue light from LED backlight. You can comfortablly read from the monitor - for as long as you want.
Product Description LG 22MB67PY - LED monitor - 22"
Device Type LED-backlit LCD monitor - 22"
Features USB Hub
Panel Type TN
Aspect Ratio 16:10
Native Resolution 1680 x 1050
Brightness 250 cd/m²
Contrast Ratio 5000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors DVI, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Dimensions (WxDxH) - with stand 50.6 cm x 23.9 cm x 36.5 cm
Weight 4.7 kg
Environmental Standards TCO Certified
Compliant Standards Plug and Play, FCC Class B certified, UL, TUV GS, cUL, ISO 13406-2, TUV Ergo, DDC/CI, EPA
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG Electronics 22MB67P...
