LG M38A 22" 1920x1080 5ms VGA LED Monitor
Key features
  • Protect your eyes and view in comfort
  • Preset customized options with just a click
  • Customize your workspace for multitasking
  • Offers improved color vision to color weakness
Product codes
Protect Your Eyes and View in Comfort
Flicker Safe and Reader Mode help maximize visual comfort by protecting your eyes from harmful blue light and reducing the flicker level to almost zero.
Preset Customized Options with just a Click
OnScreen Control and My Display Presets allow you to easily customize monitor settings with a few clicks of a mouse.
Customize Your Workspace for Multitasking
Screen Split divides the display for different tasks by resizing the windows on the screen. With PIP Mode you can work while watching a video in a window floating on the screen.
Offers Improved Color Vision to Color Weakness
Color revision algorithms are used to help those with color weakness who have difficulty distinguishing certain ranges of colors can view all the important content.
LG 22M38A - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
200 cd/m²
Contrast Ratio
600:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Screen Coating
Anti-glare, 3H Hard Coating
50.85 cm x 18.67 cm x 38.65 cm
2.4 kg
Plug and Play, DDC/CI
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG M38A 22" 1920x1080...
