LG M38H 24" 1920x1080 5ms VGA HDMI LED Monitor
Key features
  • Reader Mode
  • Flicker Safe
  • Smart Energy Saving
Product codes
This display features Flicker Safe and Reader Mode to help maximize visual comfort by protecting your eyes from harmful blue light and greatly reducing the flicker level.
Protect Your Eyes and View in Comfort
Flicker Safe and Reader Mode help maximize visual comfort by protecting your eyes from harmful blue light and reducing the flicker level to almost zero.
Preset Customized Options with just a Click
OnScreen Control and My Display Presets allow you to easily customize monitor settings with a few clicks of a mouse.
Customize Your Workspace for Multitasking
Screen Split divides the display for different tasks by resizing the windows on the screen. With PIP Mode you can work while watching a video in a window floating on the screen.
Offers Improved Color Vision to Color Weakness
Color revision algorithms are used to help those with color weakness who have difficulty distinguishing certain ranges of colors can view all the important content.
Product Description LG 24M38H-B - LED monitor - Full HD (1080p) - 23.6"
Device Type LED-backlit LCD monitor - 23.6"
Energy Class Class A
Energy Consumption per Year 31 kWh
Power Consumption (On mode) 21 W
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Brightness 200 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 5 ms
Input Connectors HDMI, VGA
Dimensions (WxDxH) - with stand 55.62 cm x 18.67 cm x 41.51 cm
Weight 2.8 kg
Compliant Standards Plug and Play, DDC/CI
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG M38H 24" 1920x1080...
