This LG IPS monitor ensures and awesome picture quality that provides clear images and vivid colors from any angle for your viewing pleasure.
Product Description | LG 24MP58VQ - LED monitor - Full HD (1080p) - 24" | Device Type | LED-backlit LCD monitor - 24" | Energy Class | Class B | Energy Consumption per Year | 36 kWh | Power Consumption (On mode) | 25 W | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Pixel Pitch | 0.2745 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Response Time | 5 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | HDMI, DVI-D, VGA | Display Position Adjustments | Tilt | Screen Coating | Anti-glare, 3H Hard Coating | Colour | Black | Dimensions (WxDxH) - with stand | 55.05 cm x 18.68 cm x 41.9 cm | Weight | 3.2 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, FCC Class B certified, UL, TUV, cUL, DDC/CI, ERP, EPA 6.0 |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Viewable Size | 23.8" |
Panel Type | IPS |
Vertical Refresh Rate | 56 - 75 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Picture in picture, HDCP, 72% (CIE 1976) colour gamut, Picture Mode, SUPER + Resolution, On-screen Digital Controls, 4-screen split, Flicker Safe, Reader Mode, SIX Axis Control, Smart Energy Saving technology, Black Stabilizer, Response Time Control, Intelligent Auto, My Display Preset, Sleek Cut Design, Color Weakness Mode, Mega DFC |
Colour | Black |
Dimensions (WxDxH) | 55.05 cm x 18.68 cm x 41.9 cm - with stand |
Weight | 3.2 kg |
Connectivity | |
Interfaces | VGA , HDMI , DVI-D , Headphones |
Mechanical | |
Tilt Angle | -2/+15 |
Miscellaneous | |
Features | Key lock |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 26 Watt |
Power Consumption Sleep | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Software / System Requirements | |
OS Required | Windows 10 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 55.05 cm - depth: 18.68 cm - height: 41.9 cm - weight: 3.2 kg , Without stand - width: 55.05 cm - depth: 8.55 cm - height: 33.21 cm - weight: 2.8 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
