LG Q6 1.4GHz Octa-Core 5.5" 32GB 13MP Android Smartphone
Key features
  • Whole lot of screen
  • Durable metal frame - durable on all sides
  • Wide selfie camera - me, you, and everyone
  • Square camera mode - share your squares
  • One hand operation - all with one hand
  • Face recognition - unlock with your smile
Product codes
The expansive 5.5" IPS Full HD+ FullVision Display gives you more to see. The 18:9 screen brings a dimension to the smartphone viewing experience. Immerse yourself in a whole new level of videos, gaming, and browsing.
The LG Q6's metal body is solidified by the lightweight "H Beam" frame made from incredibly strong 7000 series aluminum. It's designed to better endure impact from any direction.
Raise your selfie game with a 100-degree wide angle front camera to fit more friends and surroundings. The wide angle setting captures the whole scene, or set it to normal angle for closer, more personal portraits.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
BT Mobile
Product Description LG Q6 M700N - astro black - 4G LTE - 32 GB - GSM - smartphone
Product Type Smartphone 4G
Manufacturer Model Number M700N
Display LCD display - 2160 x 1080 pixels - 5.5" - 442 ppi - IPS
Features Rear-facing camera, front-facing camera
Processor Qualcomm Snapdragon 435 MSM8940 / 1.4 GHz (8-core) - 64-bit
Memory 32 GB - RAM 3 GB + microSDHC, microSDXC slot - up to 2 TB
Operating System Android 7.1.1 Nougat
Rear Camera 13 Megapixel - f/2.2 - focus: automatic
Front Camera 5 Megapixel - wide-angle lens - f/2.0
Service Provider Not specified
SIM Card Type Nano SIM
SIM Card Slot Qty Single-SIM
Wireless Interface Wi-Fi, NFC, Bluetooth
Messaging Services SMS, MMS
Connectors 3.5 mm headset jack, Micro-USB
Talk Time Up to 1320 minutes
Standby Time Up to 570 hours
Colour Astro black
Dimensions (WxDxH) 69.3 mm x 8.1 mm x 142.5 mm
Weight 149 g
SAR 1.54 W/kg (body) / 0.277 W/kg (head)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG Q6 1.4GHz Octa-Core...
