LG SJ4 2.1 Channel 300W Soundbar with Wireless Sub
FREE DELIVERY
LIMITED TIME OFFER
PRICE DROP
HIGH-RESOLUTION AUDIO AND WIRELESS SUBWOOFER! WAS £179.99!
£149.98
More than 50 in stock
Delivery:
Standard: 1-3 working days
Express: Delivered on Tuesday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • High-resolution audio
  • Wireless subwoofer
  • Adaptive sound control
  • Auto Sound Engine
  • Bluetooth Stand-by, wake up your bar on demand
  • Auto Music Play, music that follows you
  • Audio System Type: Home theatre system
  • Surround system: 2.1 channel
  • Stock Status: Clearance, Used Stock
Product codes
LG SJ4 Soundbar
Key Features:
High-Resolution Audio
Wireless Subwoofer
ASC (Adaptive Sound Control)
Auto Sound Engine
TV Matching Design
Bluetooth Stand-by
True to the Original High Resolution
A new standard of sound quality. With advanced audio processing technology delivering sound of 24bit/192kHz quality you have some of the best components available for Hi-Res Audio. Now you can listen to studio standards of sound with lossless playback, experiencing a new level of audio that is true to the original.
Wireless Subwoofer - Place your Bass Wirelessly
Free your living room from wires. LG’s active wireless subwoofer allows you to enjoy superb sound quality without compromising on design.
Adaptive Audio for what you watch
Intelligently adaptive audio. LG's unique audio enhancing technology analyses frequency levels as you listen to provide an optimum sound mix based on what you are watching. This advanced process ensures your audio instantly adapts to provide crystal clear dialogue or punchy powerful action whatever you choose to watch.
Optimised Audio
Automatically adjusted audio accuracy. LG Auto Sound Engine optimizes the audio at every volume level keeping the frequencies accurate in the right places. This delivers the correct sound balance no matter what volume your entertainment is playing at.
Sound starts the moment you transfer audio to the Soundbar. The Soundbar remains in sleep mode but turns on and begins playing when the audio is sent via Bluetooth.
Sound starts the moment you enter the room With Auto Music Play activated the bar can automatically take over the playback of the audio from a connected device the moment it sense the device is nearby.
Control with your TV Remote
LG Soundbar comes with a remote but you can choose to use your own TV remote as well. (LG, Sony, Philips, Sharp, Panasonic, Vizio, Toshiba and Samsung brand remotes).
Connected to your entertainment
Feel free to connect to the device you wish with HDMI, USB, Optical, Portable In and Bluetooth connectivity.
Product Description LG SJ4 - sound bar system - for home theatre - wireless
Product Type Sound bar system - for home theatre - 2.1-channel
Media Content Source USB-host
System Components Subwoofer, sound bar
Speaker Type Active
Nominal Output Power (Total) 300 Watt
Interfaces Bluetooth
Audio Formats WAV, WMA, MP3, FLAC, LPCM, OGG
Speaker System Details 1 x sound bar 120 Watt , 1 x subwoofer 180 Watt
Speaker Details Sound bar - main channel x 2 - 60 Watt - 10% THD - 4 Ohm - active , Speaker - subwoofer - 180 Watt - 10% THD - 3 Ohm
Built-in Decoders Dolby Digital, DTS Digital Surround
Sound Effects Sound Sync, Adaptive Sound Control (ASC)
Power AC 120/230 V (50 - 60 Hz)
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been opened but is in excellent condition
Ref: F0KP 041213
£125.92
product
Ref: F0KP 041213
Accessories
Packaging
Functional
Software
Manuals
£125.92
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG SJ4 2.1 Channel 300...
£149.98
