LG SK1 All-in-One Soundbar with Bluetooth
£89.98
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Bluetooth streaming
  • Adaptive Sound Control
  • Dynamic Range Control
  • Stock Status: Clearance
Product codes
LG SK1 - 2.1 Channel Sound Bar with Bluetooth Connectivity
Key Features
Compact Design
LG TV Sound Sync
Rich Sound in Compact Size
The compact sized all-in-one Sound Bar delivering a great balance of good sound and strong bass.
Bluetooth, stream anything
Wirelessly stream music directly from your smartphone or other compatible device for a seamless listening experience.
Bluetooth Stand-by, wake up your Sound Bar
Sound starts the moment you transfer audio to the Sound Bar. The Sound Bar remains in sleep mode but turns on and begins playing when the audio is sent via Bluetooth.
LG Sound Sync
LG Sound Sync links the Sound Bar to a compatible LG TV using an optical cable.
Product Description LG SK1 - sound bar - for home theatre - wireless
Product Type Sound bar - for home theatre
Speaker Type Active
Nominal Output Power 40 Watt
Amplifier Integrated
Interfaces Bluetooth
Audio Formats AAC, LPCM, AAC +
Speaker Details Sound bar - stereo - 2 x 20 Watt - active
Built-in Decoders Dolby Digital
Sound Effects Adaptive Sound Control (ASC), Bass Blast
Dimensions (WxDxH) 65 cm x 8.89 cm x 7.7 cm
Weight 2 kg
Manufacturer Warranty 1 year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG SK1 All-in-One Soun...
£89.98
