LG UM57 25" 2560x1080 5ms HDMI IPS Monitor
£165.62
15 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 21:9 UltraWide Full HD IPS display
  • sRGB over 99%
  • On-Screen control
  • Screen Split 2.0
  • Game mode
  • Advanced gaming features
  • Diagonal Size: 25in
  • Max Resolution: 2560 x 1080
  • Response Time: 5ms
  • Interfaces: HDMI
  • Stock Status: In Stock
Product codes
21:9 UltraWide™ QHD on IPS Display
21:9 UltraWide™ QHD (3440*1440) display offers visual comfort and ensures your best viewing pleasure. There is no color shift or no distortion of color at all.
Game Mode
Game Mode, consisting of FPS, RTS, and Custom modes, provides a customized gaming experience that varies with genres.
Fully Geared UP with Winning Features
Black Stabilizer is especially useful to detect objects including enemies that are hiding in dark areas. Dynamic Action Sync allows you to attack enemies faster with less lag time.
sRGB over 99%
An immersive work environment is ensured through realistic color expression thanks to sRGB over 99 percent and the IPS display.
Up-scaled Work Efficiency
Screen Split and PIP Mode bring you to be the real multi-tasker.
Exceptional Usability
OnScreen Control and My Display Presets allow you to easily customize monitor settings with a few clicks of a mouse.
Product Description LG 25UM58-P - LED monitor - 25"
Device Type LED-backlit LCD monitor - 25"
Energy Class Class B
Energy Consumption per Year 38 kWh
Power Consumption (On mode) 26 W
Panel Type IPS
Aspect Ratio 21:9
Native Resolution 2560 x 1080
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 5 ms
Input Connectors 2xHDMI
Dimensions (WxDxH) - with stand 60.9 cm x 18.8 cm x 38.3 cm
Weight 4 kg
Compliant Standards Plug and Play, DDC/CI
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG UM57 25" 2560x1080...
£165.62
