LG UM88C 34" 3440x1440 5ms HDMI Display Port IPS Monitor
£664.60
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • 21:9 UltraWide rules
  • 21:9 UltraWide QHD on IPS display
  • Flawless color expression
  • Advanced tech design
  • USB 3.0 quick charge
  • The big convergence of FreeSync & 21:9 UltraWide QHD
  • Diagonal Size: 34in
  • Max Resolution: 3440 x 1440
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI
Product codes
Perfect for multitasking and entertaining, the LG 21:9 UltraWide is always the right choice. A full range of 21:9 UltraWide monitors, both curved and flat, are available to meet your needs.
The 21:9 UltraWide QHD (3440 x 1440) display enables you to stretch the limits of screen real-estate. With the IPS display, visual comfort is guaranteed while ensuring vivid and accurate color expression.
You are guaranteed an immersive artwork by perceiving the same color as a subject on display or RGB color code through a sRGB over 99% color space and IPS's accurate color expression. Since color calibration tests are conducted on the production line and the Hardware Calibration Ready with a built-in scaler to directly adjust the color setting, its color accuracy is guaranteed with tools for perfect color management.
Product Description LG 34UM88C - LED monitor - 34"
Device Type LED-backlit LCD monitor - 34"
Energy Class Class B
Energy Consumption per Year 79 kWh
Power Consumption (On mode) 54 W
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 21:9
Native Resolution 3440 x 1440
Pixel Pitch 0.2325 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1
Response Time 14 ms (On/Off); 5 ms (grey-to-grey)
Colour Support 1.07 billion colours
Input Connectors 2xHDMI, DisplayPort
Display Position Adjustments Height, tilt
Dimensions (WxDxH) - with stand 82.99 cm x 25.24 cm x 42.89 cm
Weight 8.4 kg
Compliant Standards FCC Class B certified, UL, TUV, BSMI, cUL, CCC, DDC/CI, ERP, EPA 6.0
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG UM88C 34" 3440x1440...
£664.60
