LG XBOOM Go PL2 Wireless Bluetooth Speaker
£39.00
More than 50 in stock
Delivery:
Standard: 1-3 working days
Express: Delivered on Tuesday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • A sleek, portable, powerful speaker
  • Exceptional audio on the go
  • Powerful, portable audio
  • Superior sound quality
  • Pool party-proof
  • All-day battery
  • Speaker Type: Speaker
  • Connection: Wired, Wireless
  • Stock Status: In Stock
Product codes
A New Look for Balanced Sound
Simply Stylish
A sleek, rounded design with a rubberised finish is easy to hold and fits comfortably in your hand.
Experience the Sound of Excellence
LG XBOOM Go PL2 with Meridian technology gives you premium quality sound. Hear deep bass and rich tones, every time you play music.
Bring Music to Life
Sound Boost amplifies sound power and widens the sound field. Just press the button to lift the party atmosphere.
Weather-Proof Enjoyment
An IPX5 rating means your speaker can get wet and keep on working, so you can keep on dancing.
Play for Longer
A 10-hour battery life gives you the freedom to enjoy your music on-the-go without charging worries.
Multiply the Music
Wirelessly link two LG XBOOM Go PL2 to double the sound output. Bigger sound only means one thing — better parties and more fun.
Enjoy Music and More Just with Your Voice
Press the play button for two seconds, then speak to access Google Assistant on your Androidâ„¢ phone or Siri on iOS. You can play music, podcasts and more with a simple voice command.
Share Playlists with Multi Bluetooth
Pair two devices at the same time via the XBOOM App. Use any of the connected devices to seamlessly control a playlist with no interruption to music.
Answer Calls with Speaker Phone
LG XBOOM Go PL2 will automatically switch to an incoming call when music is playing, and you can easily share the call with friends.
Total Control with the XBOOM App
Control everything on one app. Get it on the Google Play Store.
Product Description LG XBOOM Go PL2 - speaker - for portable use - wireless
Product Type Speaker - for portable use
Protection Water-resistant
Enclosure Design Passive radiator
Speaker Type Active
Nominal Output Power 5 Watt
Amplifier Integrated
Interfaces Bluetooth
Intelligent Assistant Siri, Google Assistant ready - indirect
Power Options USB charging
Battery Speaker battery rechargeable - Lithium Ion
Dimensions (WxDxH) 12.6 cm x 8 cm x 8.2 cm
Weight 350 g
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG XBOOM Go PL2 Wirele...
£39.00
