Inspired by the sun, Day & Dusk automation tailors the brightness, color and temperature of your lights to compliment your day with each section of designed to enhance your health and lifestyle.
Day Dusk settings are completely customizable and designed to function around your day. You can set the routine to run only on the days you want and simply turn off sections that don’t fit in with your schedule. The choice is your
Product Description | LIFX Mini Day & Dusk - LED light bulb | Light Source Type | LED light bulb | Packaged Quantity | 4 (specifications are for single item) | Colour | Pearl white | Shape | A60 | Socket Type | B22 | Wattage | 9 W | Wattage Equivalent | 60 W | Colour of Illumination | Warm white/daylight | Colour Temperature | 1500-4000 K | Luminous Power | 800 lumens | Beam Angle | 250 degree(s) | Dimmable | Yes | Intelligent Assistant | Google Assistant, Alexa | Platform | Apple HomeKit, Google Home | Communications Technology | Wi-Fi | Voltage Required | AC 100 - 240 V | Frequency Required | 50/60 Hz |
General | |
Features | Voice activated, Wi-Fi controlled |
Light Source | |
Shape | A60 |
Socket Type | B22 |
Wattage | 9 W |
Dimmable | Yes |
Lifetime | 25000 hours |
Features | 1%-100% dimmable, Android compatible, iOS compatible, Windows Mobile compatible |
Power Requirements | |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Intelligent Assistant Compatible | Google Assistant, Alexa |
Miscellaneous | |
Body Colour | Pearl white |
Package | Box |
Compliant Standards | UL, cUL, IC, MIC, FCC, R&TTE, RoHS, PSE Mark, REACH, CQC, SAA, SRRC, EAC, RCM, TRA, FAC |
ENERGY STAR | Yes |
Warranty | 2 years |
Dimensions & Weight | |
Diameter | 60 mm |
Length | 105 mm |
Weight | 141 g |
