LIFX Mini Day & Dusk Wi-Fi Smart LED Light Bulb B22 - 4 Pack
£109.99
Select:
17 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Built-in Wi-Fi
  • Bright (800 lumens)
  • Dimmable
  • Warm sunset to daylight white
  • LIFX app control & cloud
  • Energy Star compliant
  • Voice control compatible
  • Type: Light bulb
  • Compatible With: Alexa, Google Assistant
  • Stock Status: In Stock
Product codes
Inspired by the sun, Day & Dusk automation tailors the brightness, color and temperature of your lights to compliment your day with each section of designed to enhance your health and lifestyle.
  • Set your wake up time and ease into the morning with soft daylight whites
  • During the day, stay active with natural and bright white tones
  • As the evening sets in, a calming amber glow will help unwind
  • When bedtime comes around, your lights fade to a dim night light or to completely off
Day Dusk settings are completely customizable and designed to function around your day. You can set the routine to run only on the days you want and simply turn off sections that don’t fit in with your schedule. The choice is your
Product Description LIFX Mini Day & Dusk - LED light bulb
Light Bulb Type LED light bulb
Packaged Quantity 4 (specifications are for single item)
Colour Pearl white
Shape A60
Socket Type B22
Wattage 9 W
Wattage Equivalent 60 W
Colour of Illumination Warm white/daylight
Colour Temperature 1500-4000 K
Luminous Power 800 lumens
Beam Angle 250 degree(s)
Dimmable Yes
Voltage Required AC 100 - 240 V
Frequency Required 50/60 Hz
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LIFX Mini Day & Dusk W...
£109.99
