We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
No colors or frills, just good old-fashioned illumination at your command. This Wi-Fi smart light is perfect for easy, affordable smart lighting in home or work.
Product Description | LIFX Mini White - LED light bulb - shape: A19 - E27 - 9 W - warm white light - 2700 K - pearl white | Light Source Type | LED light bulb | Colour | Pearl white | Shape | A19 | Socket Type | E27 | Wattage | 9 W | Energy Efficiency Class | F | Colour of Illumination | Warm white light | Colour Temperature | 2700 K | Luminous Power | 800 lumens | Beam Angle | 250 degree(s) | Dimmable | Yes | Voltage Required | AC 100 - 240 V | Frequency Required | 50/60 Hz |
Light Source | |
Shape | A19 |
Socket Type | E27 |
Wattage | 9 W |
Energy Consumption per 1000h | 9 kWh |
Colour Rendering Index | 80 |
Dimmable | Yes |
Features | 1%-100% dimmable, Android compatible, iOS compatible, Windows compatible, voice activated, Wi-Fi controlled |
Power Requirements | |
Power Consumption Stand by | 0.5 Watt |
Miscellaneous | |
Body Colour | Pearl white |
Compliant Standards | UL, cUL, IC, MIC, FCC, R&TTE, RoHS, PSE Mark, REACH, CQC, SAA, SRRC, EAC, RCM, TRA, FAC |
ENERGY STAR | Yes |
Warranty | 2 years |
Dimensions & Weight | |
Diameter | 59 mm |
Length | 105 mm |
Weight | 141 g |
Shipping Dimensions (WxDxH) / Weight | 63 mm x 63 mm x 125 mm / 177 g |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
