LightwaveRF Gen 2 Lighting & Power Starter Kit
FREE DELIVERY
£229.00
Colours:
11 in stock
Delivery:
Standard: 1-3 working days
  • Compatible With: Alexa, Google Assistant
  • Stock Status: In Stock
Product codes
L21422 (Generation 2) Lighting & Power Starter Kit
Begin your home automation adventure with the Lighting & Power Starter Kit. With a Link Plus, a 1 gang smart dimmer, and a 2 gang smart socket, you'll have everything you need to start controlling your lamps, appliances, and more. This model incorporates all the great features from our Generation 1 products and adds Apple HomeKit compatibility, 2-way communication, built-in energy monitoring, and more! The dimmer and socket are quick and easy to DIY install and do not require extra cabling.
HomeKit Control
Lightwave’s remote control dimmer switch seamlessly integrates with Apple HomeKit, so you can control your home and make optimal use of smart lighting from your smartphone or tablet, from wherever you are.
Easy compatibility
A contemporary stainless steel finish houses an all-new 350W smart dimmer to ensure compatibility with the majority of current dimmable LED lamps.
Feature rich
Our second generation dimmer light switch offers soft-start illumination, 2-way switching as default, energy monitoring and multi-way wireless communication with other Lightwave dimmers.
Simple installation
Standard wiring configurations make the smart light dimmer switch easy to DIY install or via a suitably qualified electrician. A 10mm spacer is included for shallower back boxes.
Product Specifications
Control Lightwave devices
Link Plus compatible with Gen 1 & Gen 2 devices (excluding Gen 1 remotes and wire-free switches)
Compatibility
Works with Apple HomeKit, Amazon Alexa, Google Assistant and IFTTT
DIY retrofit
All Lightwave devices are safe and legal to DIY retrofit in your own home
Product Description LightwaveRF L21422 - 2nd Generation - Lighting & Power Starter Kit - home automation kit
Product Type Home automation kit
Functions Energy use monitor, light control
Power Source Power adapter
Internet of Things (IoT) Platform Apple HomeKit
Intelligent Assistant Google Assistant, Alexa
Package Content Central controller, dimmer, smart socket
Connectivity Wireless
Colour Stainless steel
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LightwaveRF Gen 2 Ligh...
£229.00
