LightwaveRF Gen 2 Lighting Starter Kit
FREE DELIVERY
£174.00
Colours:
Delivery:
Key features
  • Easy compatibility
  • Feature rich
  • Simple installation
  • Type: Wireless light switch
  • Compatible With: Alexa, Google Assistant
Product codes
L212 (Generation 2) Lighting Starter Kit
Beautifully designed smart dimmers to help you control your home lighting from wherever you are.
Begin your home automation adventure by using our stylish smart dimmer to control your lights. With a Link Plus and a 1 gang smart dimmer, you'll have everything you need to start controlling your lights, setting scenes, and making automations. This model incorporates all the great features from our Generation 1 products and adds Apple HomeKit compatibility, 2-way communication, built-in energy monitoring, and more! This dimmer is quick and easy to DIY install.
HomeKit Control
Lightwave’s remote control dimmer switch seamlessly integrates with Apple HomeKit, so you can control your home and make optimal use of smart lighting from your smartphone or tablet, from wherever you are.
Easy compatibility
A contemporary stainless steel finish houses an all-new 350W smart dimmer to ensure compatibility with the majority of current dimmable LED lamps.
Feature rich
Our second generation dimmer light switch offers soft-start illumination, 2-way switching as default, energy monitoring and multi-way wireless communication with other Lightwave dimmers.
Simple installation
Standard wiring configurations make the smart light dimmer switch easy to DIY install or via a suitably qualified electrician. A 10mm spacer is included for shallower back boxes.
Control Lightwave devices
Link Plus compatible with Gen 1 & Gen 2 devices (excluding Gen 1 remotes and wire-free switches)
Compatibility
Works with Apple HomeKit, Amazon Alexa, Google Assistant and IFTTT
DIY retrofit
All Lightwave devices are safe and legal to DIY retrofit in your own home
Product Description LightwaveRF L212 - 2nd Generation - Lighting Starter Kit - home automation kit
Product Type Home automation kit
Functions Energy use monitor, light control
Internet of Things (IoT) Platform Apple HomeKit
Package Content Central controller, dimmer
Connectivity Wireless
Colour White, stainless steel
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LightwaveRF Gen 2 Ligh...
£174.00
