LightwaveRF Gen 2 Smart Dimmer 1 Gang - White
FREE DELIVERY
£59.95
Colours:
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered on Friday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
  • Type: Wireless light switch
  • Compatible With: Alexa, Apple Homekit, Google Assistant, IFTTT
  • Stock Status: In Stock
Product codes
Bundle deals (1)
REQUIRES LINK PLUS FOR OPERATION
= £179.95
Save £10.00
L21 (Generation 2) - Smart Dimmer
Beautifully designed smart dimmers to help you control your home lighting from wherever you are.
Begin your home automation adventure by using our stylish smart dimmer to control your lights. This model incorporates all the great features from our Generation 1 products and adds Apple HomeKit compatibility, 2-way communication, built-in energy monitoring, and more! The dimmer is quick and easy to install and is also available in a 2 gang version. Available in Stainless Steel and White Metal finishes, and includes an optional 10mm spacer.
Generation 2 device
Requires Link Plus and Link Plus App for operation
Compatibility
Works with Apple HomeKit, Amazon Alexa, Google Assistant and IFTTT.
DIY retrofit
All Lightwave devices are safe and legal to DIY retrofit in your own home.
Easy compatibility
A contemporary stainless steel finish houses an all-new 350W smart dimmer to ensure compatibility with the majority of current dimmable LED lamps.
Feature rich
Our second generation dimmer light switch offers soft-start illumination, 2-way switching as default, energy monitoring and multi-way wireless communication with other Lightwave dimmers.
Simple installation
Standard wiring configurations make the smart light dimmer switch easy to DIY install or via a suitably qualified electrician. A 10mm spacer is included for shallower back boxes.
HomeKit Control
Lightwave’s remote control dimmer switch seamlessly integrates with Apple HomeKit, so you can control your home and make optimal use of smart lighting from your smartphone or tablet, from wherever you are.
Product Description LightwaveRF L21WH - dimmer
Product Type Dimmer
Power Source Hardwired
Connectivity Wireless
Frequency Band 868 MHz
Colour White
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LightwaveRF Gen 2 Smar...
£59.95
