LightwaveRF Gen 2 Smart Socket 2 Gang - White
FREE DELIVERY
£59.95
Colours:
Delivery:
Key features
  • Schedule appliances
  • Stay secure
  • Type: Smart plug
  • Compatible With: Alexa, Apple Homekit, Google Assistant, IFTTT
Product codes
Bundle deals (1)
REQUIRES LINK PLUS FOR OPERATION
= £179.95
Save £10.00
L42 - Smart Socket (2 gang)
Bring your home to life. Beautifully designed smart sockets to help control your appliances from wherever you are.
Begin your home automation adventure by using our stylish smart socket to control your lamps, appliances, and more. This model incorporates all the great features from our Generation 1 products and adds Apple HomeKit compatibility, 2-way communication, built-in energy monitoring, and more! This socket is quick and easy to DIY install. Available in Stainless Steel and White Metal finishes, and includes an optional 10mm spacer.
HomeKit Control
Lightwave’s remote socket seamlessly integrates with Apple HomeKit, so you can control your home and make optimal use of smart devices from your smartphone or tablet, from wherever you are.
Wireless socket
A contemporary stainless steel or white metal finish and fully 3000W rated like any other 1 gang or 2 gang socket; however, you can control a Lightwave smart socket from your smartphone.
Feature rich
Our second generation smart socket enables real-time status updates of any connected appliances and built-in energy monitoring. All Lightwave sockets are also lockable to ensure family safety.
Simple installation
Standard wiring configurations make our smart wifi socket easy to DIY install or via a suitably qualified electrician. A 10mm spacer is included for shallower back boxes.
Generation 2 device
Requires Link Plus and Link Plus App for operation
Compatibility
Works with Apple HomeKit, Amazon Alexa, Google Assistant and IFTTT
DIY retrofit
All Lightwave devices are safe and legal to DIY retrofit in your own home
Product Description LightwaveRF L42 Smart Socket (2 gang) - smart plug
Product Type Smart plug
Functions Energy use monitor
Internet of Things (IoT) Platform Apple HomeKit
Connectivity Wireless
Colour Metal white
Dimensions (WxDxH) 15 cm x 3 cm x 8.8 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LightwaveRF Gen 2 Smar...
£59.95
