LightwaveRF Link Plus
FREE DELIVERY
£129.96
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
  • Type: Central controller
  • Compatible With: Alexa, Apple Homekit, Google Assistant, IFTTT
  • Stock Status: In Stock
Product codes
LightwaveRF L2 - Link Plus
Smart-yet-simple advanced control that helps you to automate your home from wherever you are.
Discover the superior integration capabilities of the new Lightwave Link Plus controller, which powers a world of smart features. The Link Plus is the core of any Lightwave smart home, allowing you to control and automate your home however you like.
Generation 2
Our superior second generation Lightwave Link Plus controller is designed to work seamlessly with Apple HomeKit, Amazon Alexa, Google Home and more.
Central control
The Lightwave Link Plus receives and passes on commands from the App, allowing you to control over 200 individual Lightwave devices in the home from wherever you are.
All smart devices
You can use the Lightwave Link Plus and our App to control Lightwave devices including dimmers, switches, sockets, heating, alert systems and outdoor lighting.
Superior range
Outperforms most WiFi routers and covers up to 4 rooms or 3 floors easily
Compatibility
Works with Apple HomeKit, Amazon Alexa, Google Assistant and IFTTT
Setup
Setup in just few minutes use to control Generation 1 and Generation 2 devices
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£129.96
