Logitech B100 Optical Mouse Black
PLUG & PLAY USB MOUSE
£6.36
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • A comfortable plug-and-play mouse with built-in quality and optical precision.
  • Comfortable, ambidextrous design
  • 800 dpi optical precision
  • Zero setup
  • Built by Logitech
  • Comfort in hand
  • Smooth operator
  • Ready in no time
  • Type: Mouse
  • Wired / Wireless: Wired
  • Colour: Black
  • Compatibility: Mac, PC, Unix
  • Stock Status: In Stock
Product codes
A comfortable plug-and-play mouse with built-in quality and optical precision!
You'll enjoy smooth, precise cursor control that lets you edit documents and navigate the Web more efficiently.
It works right out of the box - you just plug it into your USB port and you're ready for business.
Left-handed or right, you can work comfortably all day long with this ambidextrous mouse.
You're in control with smooth, responsive optical tracking that moves the cursor just where you want it.
Product Description Logitech B100 - mouse - USB - black
Device Type Mouse
Connectivity Technology Wired - USB
Colour Black
Orientation Right and left-handed
Dimensions (WxDxH) 6.17 cm x 11.3 cm x 3.84 cm
Weight 85 g
Movement Detection Technology Optical
Buttons Qty 3
Movement Resolution 800 dpi
Features Scrolling wheel
Cables Included 1 x USB cable - integrated - 1.8 m
OS Required Linux 2.4 or later, Microsoft Windows 7, Apple MacOS X 10.3.9 or later, Microsoft Windows Vista / XP
Microsoft Certification Compatible with Windows 7
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Logitech B100 Optical...
£6.36
