Logitech B100 Optical Mouse for Business Black
PLUG & PLAY USB MOUSE
£6.94
More than 50 in stock
Delivery:
Standard: 3-5 working days
Key features
  • A comfortable plug-and-play mouse with built-in quality and optical precision.
  • Comfortable, ambidextrous design
  • 800 dpi optical precision
  • Zero setup
  • Built by Logitech
  • Comfort in hand
  • Smooth operator
  • Ready in no time
Product codes
Bundle deals (1)
TPLINK 25W 5-PORT USB CHARGER
£6.94
= £19.94
Save £3.00
    The comfortable, lower-profile shape feels good in either hand-even after a long day of work
    You'll enjoy smooth, precise cursor control that lets you edit documents and navigate the Web more efficiently
  • Zero setup
    It works right out of the box-you just plug it into your USB port and you're ready for business
  • Built by Logitech
    This mouse comes with the quality and design we've built into more than a billion mice, more than any other manufacturer
  • Comfort in hand
    Left-handed or right, you can work comfortably all day long with this ambidextrous mouse
  • Smooth operator
    You're in control with smooth, responsive optical tracking that moves the cursor just where you want it
  • Ready in no time
    This plug-and-play mouse is simple to set up-you just plug it in to your USB and get back to business
A comfortable plug-and-play mouse with built-in quality and optical precision!
You'll enjoy smooth, precise cursor control that lets you edit documents and navigate the Web more efficiently.
It works right out of the box - you just plug it into your USB port and you're ready for business.
Left-handed or right, you can work comfortably all day long with this ambidextrous mouse.
You're in control with smooth, responsive optical tracking that moves the cursor just where you want it.
Logitech B100 - mouse - USB - black
Mouse
Wired - USB
Orientation
Right and left-handed
6.17 cm x 11.3 cm x 3.84 cm
85 g
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
800 dpi
Scrolling wheel
1 x USB cable - integrated - 1.8 m
Linux 2.4 or later, Microsoft Windows 7, Apple MacOS X 10.3.9 or later, Microsoft Windows Vista / XP
Microsoft Certification
Compatible with Windows 7
3 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Logitech B100 Optical...
£6.94
