Step up to the world's most technologically advanced webcam and get professional-quality video for conference calls, streaming, or video recording. Our first 4K ultra high-def camera offers 5x digital zoom and RightLight 3 with HDR. Background replacement gives you the freedom to meet anywhere.
Product Description | Logitech BRIO 4K Ultra HD webcam - webcam | Device Type | Webcam | Audio | Yes: built-in dual stereo microphones | Camera Mount Type | Tripod mount | Dimensions (WxDxH) | 10.2 cm x 2.7 cm x 2.7 cm | Weight | 63 g | Connectivity Technology | Wired | Camera | Colour | Max Resolution | 4096 x 2160 | Frame Rate (max) | 30 frames per second | Video Modes | 720p, 1080p, 4K | Focus Adjustment | Automatic | Interfaces | USB | Cables Included | 1 - USB cable - 1.5 m | Features | Passive infrared sensor, High Dynamic Range (HDR), 4K ULTRA HD engine, RightLight 3 technology, Infrared Facial Recognition | Manufacturer Warranty | 3-year warranty | Works With Chromebook | Yes |
General | |
Audio Support | Yes: built-in dual stereo microphones |
Width | 10.2 cm |
Depth | 2.7 cm |
Height | 2.7 cm |
Weight | 63 g |
Camera | |
Type | Colour |
Max Digital Video Resolution | 4096 x 2160 |
Digital Zoom | 5 |
Video Capture | 4096 x 2160 @ 30 fps , 1920 x 1080 @ 60 fps , 1280 x 720 @ 90 fps |
Lens Construction | |
Interfaces | |
Computer Interface | USB |
Miscellaneous | |
Included Accessories | Removable clip, privacy shutter, carrying pouch |
Cables Included | 1 x USB cable - 1.5 m |
Compliant Standards | Plug and Play |
Software / System Requirements | |
OS Required | Apple MacOS X 10.10, Microsoft Windows 7 / 8.1 / 10, Google Chrome OS 29 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
