We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Versatile Accessory For Your Wire-Free Camera
Circle 2 Accessory Rechargeable Battery works with Circle 2 indoor/outdoor wire-free security camera only. Use it as a backup to power your Circle 2 camera while the other battery is charging. Circle 2 is the most versatile security camera that can be used anywhere at home. To customise your experience even more, choose from a selection of accessories that fit your needs.
Use this rechargeable battery as a backup battery for the Circle 2 wire-free camera. It can last up to 3 months on a single charge.
Product Description | Logitech battery - Li-Ion | Product Type | Battery | Dimensions (WxDxH) | 8.2 cm x 8.2 cm x 4.2 cm | Weight | 256 g | Battery | Lithium Ion - 6400 mAh | Manufacturer Warranty | 1-year warranty |
General | |
Designed For | Camera |
Width | 8.2 cm |
Depth | 8.2 cm |
Height | 4.2 cm |
Weight | 256 g |
Battery | |
Technology | Lithium Ion |
Capacity | 6400 mAh |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
