We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Type, view, sketch, and read with Folio Touch, the incredibly versatile keyboard case with trackpad for iPad Pro. Use your iPad Pro in whole new ways thanks to an adjustable kickstand for optimized viewing, foldable keyboard for laptop-like typing, and a high-precision trackpad for greater control in your favorite apps.
Product Description | Logitech Folio Touch - keyboard and folio case - with trackpad - QWERTY - UK - oxford grey | Device Type | Keyboard and folio case | Backlit | Yes | Interface | Apple Smart connector | Input Device | Keyboard | Connectivity Technology | Wired | Built-in Devices | Trackpad | Localization and Layout | QWERTY UK | Hot Keys Function | Search, mute, brightness, screen lock, play/pause, previous track, next track, home screen, on screen keyboard, volume -, volume + | Protection | Scratch-resistant, spill-resistant, scuff-resistant | Colour | Oxford grey | Case Material | Woven fabric | Dimensions (WxDxH) | 18.9 cm x 2.1 cm x 25.6 cm | Weight | 642.5 g | Manufacturer Warranty | 1-year warranty | Designed For | Apple 10.9-inch iPad Air (4th generation) |
General | |
Backlit | Yes |
Input Device | |
Type | Keyboard |
Width | 18.9 cm |
Depth | 2.1 cm |
Height | 25.6 cm |
Weight | 642.5 g |
Carrying Case | |
Features | Magnetic closure, pen holder, adjustable viewing angles, ports and controls access, auto sleep/wake function |
Miscellaneous | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Compatibility Information | |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
