Logitech G213 Prodigy Gaming Keyboard
£62.13
34 in stock
Delivery:
Standard: 1-3 working days
Key features
  • The G213 Prodigy gaming keyboard features Logitech Mech-Dome keys that are specially tuned to deliver a superior tactile response and performance profile similar to a mechanical keyboard. Mech-Dome keys are full height, deliver a full 4mm travel distance, 50g actuation force, and a quiet sound operation. The G213 Prodigy gaming keyboard was designed for gaming, featuring ultra-quick, responsive feedback that is up to 4x faster than the 8ms report rate of standard keyboards and an anti-ghosting matrix that keeps you in control when you press multiple gaming keys simultaneously.
  • Gaming Grade Performance
  • Crisp, Brilliant RGB Lighting Zones
  • Spill-Resistant and durable
  • Integrated Palm Rest & Adjustable Feet
  • Dedicated Media Controls
  • Recommended Use: Gaming
  • Type: Keyboard
  • Wired / Wireless: Wired
  • Colour: Black
  • Compatibility: PC
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £65.62
Save £1.50
The G213 Prodigy gaming keyboard features Logitech Mech-Dome keys that are specially tuned to deliver a superior tactile response and performance profile similar to a mechanical keyboard. Mech-Dome keys are full height, deliver a full 4mm travel distance, 50 g actuation force, and a quiet sound operation. The G213 Prodigy gaming keyboard was designed for gaming, featuring ultra-quick, responsive feedback that is up to 4x faster than the 8 ms report rate of standard keyboards and an anti-ghosting matrix that keeps you in control when you press multiple gaming keys simultaneously.
Product Description Logitech Prodigy G213 - keyboard - QWERTY - UK
Device Type Keyboard
Backlit 16.8 million colours
Interface USB
Connectivity Technology Wired
Localization and Layout QWERTY UK
Hot Keys Function Mute, play/pause, stop, previous track, next track, volume -, volume +
Protection Spill-resistant
Numeric Keypad Yes
Dimensions (WxDxH) 45.2 cm x 218 cm x 3.3 cm
Weight 1 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Logitech G213 Prodigy...
£62.13
