Logitech G27 Racing Wheel - Wheel, Pedals & Gear Shift Le...
Logitech G27 Racing Wheel - Wheel, Pedals & Gear Shift Lever Set - PC, PS3 & PS2
Key features
  • Dual-motor force feedback mechanism with helical gearing
  • RPM/shift indicator LEDs
  • Sixteen programmable buttons plus D-pad
  • 900-degree wheel rotation
  • Ultra-precise optical encoding
  • Carpet grip system
Product codes
Documents
Logitech G27 - real metal, real leather, real racing
A simulator-grade racing wheel, the Logitech® G27 Racing Wheel is designed to deliver the definitive sim racing experience for the PC and PLAYSTATION®3. Its powerful, dual-motor force feedback mechanism with helical gearing smoothly and accurately simulates traction loss, weight shift and road feel, with exceptionally quiet steering action. The six-speed shifter with push-down reverse gear allows you to quickly choose exactly the right gear. New RPM/shift indicator LEDs let you know when you should shift gears; the 28-cm (11") leather-wrapped rim provides hours of comfortable, true-to-life racing; and steel accelerator, brake and clutch pedals deliver precise control for heightened realism.
The Logitech G27 Racing Wheel was designed to deliver the definitive sim racing experience. Whether sliding sideways around a gravelly curve, or screaming through the streets of Monaco, the world's greatest circuits feel closer than ever.
Feel the race
You feel your car's weight shift and tires slip thanks to the dual-motor force feedback with helical gearing.
Shift your way
You can quickly select the correct gear with either the six-speed shifter or the F1-style paddles.
You'll experience traction loss, weight shift, and road feel recreated smoothly and accurately. Helical gearing provides the exceptionally quiet steering action.Force feedback - You can really feel it.
You can tune your car to max out its horsepower. You can drive day and night to hone your skills. But road conditions can only be transmitted through the feel of the steering wheel you're using.
On top of accurately registering collisions, a force feedback wheel can provide subtle information about how your car is performing. Throttle too hard and you'll feel your tires starting to lose grip. Lose control of the car's rear end and the wheel will fight against you as you counter-steer to regain control.
Six-speed shifter
You can quickly select exactly the right gear for the turn or the straightaway. The push-down reverse gear lets you back up realistically.
Keeping an eye on the indicator panel lets you know just when to shift gears for maximum torque (in supported games).
Hand-stitched leather
The 11-inch wheel is wrapped in real leather to help keep your hands comfortable from the start line to the checkered flag.
Steel gas, brake, and clutch pedals
Sturdy true-to-life pedals deliver precise throttle, braking, and shifting control for heightened realism.
You can go 2.5 times around lock to lock--just as you would behind the wheel of many real cars.
16 programmable buttons plus D-pad
You can map useful game functions to locations that make sense to you--whether on the wheel itself or on the shift module.
Custom tuned for popular games
There are no dead zones or lag, so you'll see and feel every bit of wheel movement reflected in-game.
Optical encoding
You'll enjoy reliable and accurate handling race after race after race.
Carpet grip system
Retractable teeth flip down to keep the pedals from sliding around on carpeting.
Steel ball bearings
Two sets of solid steel ball bearings support the wheel shaft for superb performance and long-term reliability.
Hard points
All three components (wheel console, pedals, and shifter module) can be bolted to a table or other surface for a solid racing experience.
Product Description Logitech G27 Racing - wheel, pedals and gear shift lever set - wired
Product Type Wheel, pedals and gear shift lever set
Connectivity Technology Wired
Microsoft Certification Compatible with Windows 7
Manufacturer Warranty 1-year warranty
Designed For Sony PlayStation 2, PC, Sony PlayStation 3
Resources
The following resources are available for the Logitech G27 Racing Wheel - Wheel, Pedals & Gear Shift Lever Set - PC, PS3 & PS2
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
