Logitech G403 Prodigy Gaming Wired Mouse
£54.87
19 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Supreme comfort
  • Gaming-Grade Performance
  • Elevate Your Accuracy
  • Adjustable weight system
  • Programmable RGB Lighting
  • Advanced button tensioning
  • Onboard memory
  • Six programmable buttons
  • Programmable DPI settings
Product codes
With rubber grips on the left and right sides to give you added control, the G403 Prodigy was made to mold to your hand for long-lasting comfort during gameplay. In a lightweight, ergonomically designed body, G403 brings together supreme comfort, quality, and durability.
With G403 Prodigy, the game gets better and so do you. Prodigy is built for gaming speed, accuracy and endurance. With a 1ms report rate, G403 is up to 8x faster than standard mice - which means when the mouse is moved or clicked, the response is near-instantaneous.
Become more accurate than you've ever been before. The G403 Prodigy features the world's most advanced gaming mouse sensor, used by eSports pros worldwide. Exceptionally precise and consistent, it gives you the confidence of quicker responses and more accurate targeting.
Logitech Gaming Mouse G403 Prodigy - mouse - USB
Mouse
Wired - USB
6.8 cm x 12.4 cm x 4.3 cm
87.3 g
Movement Detection Technology
Optical
Buttons Qty
6
Movement Resolution
12000 dpi
Performance
1 ms response time, 1000 reports per second, 40 G maximum acceleration, realtime sensitivity switching 200 - 12000 dpi, 300 inches per second
Adjustable weight, built-in flash memory, 6 programmable buttons, 16.8 million multi-colour illumination
Cable Length
2.13 m
Microsoft Windows 7 / 8 / 8.1 / 10
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Logitech G403 Prodigy...
£54.87
