G413 was thoughtfully conceived, designed and engineered to deliver advanced performance with just the right feature set. Lightweight, high-strength 5052 aluminum alloy top case enables the slim, bladelike chassis. Underneath find mouse and headset cable management, plus adjustable-height feet with rubber stabilizers, for confidence during intense gameplay.
The Romer-G mechanical switch is purpose-built for pro-grade performance, responsiveness and durability. The short-throw actuation at 1.5mm offers a perfect blend of speed, precision and quiet performance, Romer-G is the stealth assassin of mechanical gaming keyboard switches.
Product Description | Logitech G413 - keyboard - UK English - silver | Device Type | Keyboard | Backlit | White | Interface | USB | Layout | UK English | Hot Keys Function | Multimedia, programmable, backlight control, gaming mode key | Numeric Keypad | Yes | Key Switch Type | Romer-G | Colour | Silver | Dimensions (WxDxH) | 44.5 cm x 13.2 cm x 3.4 cm | Weight | 1.105 kg | Manufacturer Warranty | 2-year warranty |
General | |
Backlit | White |
Interface | USB |
Input Device | |
Keyboard Technology | Mechanical |
Adjustable Height | Yes |
Detachable Cable | Yes |
Features | Numeric keypad |
Width | 44.5 cm |
Depth | 13.2 cm |
Height | 3.4 cm |
Weight | 1.105 kg |
Expansion / Connectivity | |
Interfaces | USB 2.0 |
Miscellaneous | |
Colour | Silver |
Cable Length | 1.8 m |
Included Accessories | Keycap puller, 12 keycaps |
Software & System Requirements | |
OS Required | Microsoft Windows 7 / 8 / 8.1 / 10 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
