Logitech G502 Proteus Spectrum RGB Tunable Gaming Mouse
£64.02
27 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Accurate responsive optical sensor
  • BALANCE AND WEIGHT AT YOUR CONTROL
  • Programmable RGB Lighting
  • Personally-tuned performance
  • 11 Programmable buttons
  • DPI SHIFT IN-GAME
  • DUAL-MODE, GAMING-GRADE SCROLL WHEEL
  • ADDITIONAL FEATURES
Product codes
Get maximum tracking accuracy from the most responsive optical sensor (PMW3366). Exclusive Logitech G Delta Zero optical sensor technology minimizes mouse acceleration and increases reliable targeting. Switch DPI modes on the fly - choose from five settings from 200 to 12,000 DPI. Customize to your advantage. Five 3.6g weights come with your Proteus Spectrum. Use some or all of them in the positions where you like more weight, or less. This mouse can be tailored to your preferences.
Logitech Proteus Spectrum G502 - mouse - USB
Mouse
Wired - USB
7.5 cm x 4 cm x 13.2 cm
168 g
Movement Detection Technology
Optical
Buttons Qty
11
Movement Resolution
12000 dpi
Performance
1 ms response time, 40 G maximum acceleration, realtime sensitivity switching 200 - 12000 dpi, 300 inches per second
Programmable buttons, scrolling wheel, rubber side grips, sensitivity adjustment, adjustable weight, braided cable, 3 profiles, 16.8 million multi-colour illumination, ARM 32-bit processor
Windows 8.1, Microsoft Windows 7 / 8 / 10
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Logitech G502 Proteus...
£64.02
