Logitech G603 Lightspeed Wireless Gaming Mouse
£69.21
Delivery:
Notify me
Key features
  • HERO is a revolutionary new optical sensor designed by Logitech G to deliver class-leading performance and up to 10 times the power efficiency 1 . With HERO sensor, G603 also delivers exceptionally accurate and consistent performance across the entire DPI range, with zero smoothing, filtering or pixel rounding from 200 to 12,000 DPI. Learn more about HERO sensor
  • Next Generation HERO Sensor
  • LIGHTSPEED Wireless
  • Advanced Power Management
  • Connect to Multiple Devices
  • Ergonomically Designed and Customizable
  • Recommended Use: Gaming
  • Type: Mouse
  • Wired / Wireless: Wireless
  • Colour: Black
  • Compatibility: PC
Product codes
HERO is a revolutionary optical sensor designed by Logitech G to deliver amazing performance and up to 10 times the power efficiency. With HERO sensor, G603 also delivers exceptionally accurate and consistent performance across the entire DPI range, with zero smoothing, filtering or pixel rounding from 200 to 12,000 DPI.
LIGHTSPEED wireless technology features a super fast 1 ms report rate with the end-to-end optimized wireless solution. G603 delivers incredible responsiveness and reliability for competition-level performance.
Product Description Logitech G603 - mouse - Bluetooth, LIGHTSPEED
Device Type Mouse
Connectivity Technology Wireless - Bluetooth, LIGHTSPEED
Dimensions (WxDxH) 6.8 cm x 12.4 cm x 4.3 cm
Weight 87 g
Wireless Receiver USB wireless receiver
Movement Detection Technology Optical
Buttons Qty 6
Movement Resolution 12000 dpi
Performance 40 G maximum acceleration, realtime sensitivity switching 200 - 12000 dpi, polling rate: 1000 Hz
Features Scrolling wheel, ARM 32-bit processor, HERO sensor
Battery AA type
OS Required Google Chrome OS, Microsoft Windows 7 or later, Android 3.2 (Honeycomb) or later, Apple MacOS X 10.10 or later
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£69.21
Notify me
