G703 features LIGHTSPEED wireless technology, the PMW 3366 sensor and advanced button tensioning for incredible responsiveness for competition-level twitch targeting. G703 is ergonomically designed for long-lasting comfort.
Product Description | Logitech Gaming Mouse G703 - mouse - USB, 2.4 GHz - black | Device Type | Mouse | Connectivity Technology | Wireless, wired - USB, 2.4 GHz | Colour | Black | Dimensions (WxDxH) | 6.8 cm x 12.4 cm x 4.3 cm | Weight | 107 g | Wireless Receiver | USB wireless receiver | Movement Detection Technology | Optical | Buttons Qty | 6 | Movement Resolution | 12000 dpi | Performance | 1 ms response time, 40 G maximum acceleration, realtime sensitivity switching 200 - 12000 dpi, up to 400 inches per second | Features | Scrolling wheel, rubber side grips, sensitivity adjustment, adjustable weight, built-in flash memory, 6 programmable buttons, ARM 32-bit processor, Pixart PMW 3366 optical gaming sensor, RGB 16.8 millions multi-colour illumination | Cable Length | 1.83 m | OS Required | Microsoft Windows 7 / 8 / 8.1 / 10, Apple MacOS X 10.10 or later | Manufacturer Warranty | 2-year warranty |
General | |
Width | 6.8 cm |
Depth | 12.4 cm |
Height | 4.3 cm |
Weight | 107 g |
Colour | Black |
Input Device | |
Connectivity Technology | Wireless, wired |
Interface | USB, 2.4 GHz |
Buttons Qty | 6 |
Expansion / Connectivity | |
Interfaces | 1 x USB - 4 pin USB Type A |
Miscellaneous | |
Included Accessories | USB wireless adapter, charging cable, adjustable weight cartridge (10 g) |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
