Logitech G903 LIGHTSPEED Wireless Gaming Mouse
£149.42
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • LIGHTSPEED Wireless
  • Our Most Accurate Optical Sensor
  • Lightweight Construction
  • Customizable Ambidextrous Design
  • Power-efficient technology
  • Wired and Wireless
  • POWERPLAY Wireless Charging-Compatible
  • Customizable Weight
  • Exclusive Clock-Tuning Technology
  • Mechanical Pivot Button Design
  • Onboard memory
  • 11 Programmable Buttons
  • Programmable RGB Lighting
  • Programmable DPI settings
Product codes
In high-pressure moments, latency can be the difference between winning it all or losing. With millions on the line, esports professionals around the world depend on Lightspeed wireless technology. Featuring a high report rate and end-to-end optimized wireless connectivity, G903 delivers incredible responsiveness for competition-level twitch targeting. G903 comes equipped with advanced optical sensor. Thanks to years upon years of innovations, it has zero smoothing, filtering, or acceleration across the entire DPI range. The resulting experience is incredible tracking accuracy and consistent responsiveness even at high speeds.
Precisely-tensioned metal springs and exclusive mechanical-pivot hinges keep the primary left and right mouse buttons poised to trigger. This technology delivers an exceptionally clean and crisp button feel, response, and consistency. Designed to be ultra-lightweight and customizable, every component of G903 has been optimized to reduce weight while maintaining stability. Each element of the construction was analyzed and adjusted to remove milligrams to create a wireless mouse that is ultra-light. Configurable button layout and ambidextrous design allow for left- or right-handed use that works with nearly any mouse grip style, including palm, claw and fingertip grips.
Logitech Gaming Mouse G903 - mouse - USB, 2.4 GHz
Mouse
Wireless, wired - USB, 2.4 GHz
Orientation
Right and left-handed
6.65 cm x 13.03 cm x 4.04 cm
110 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
11
Movement Resolution
12000 dpi
Performance
1 ms response time, 40 G maximum acceleration, realtime sensitivity switching 200 - 12000 dpi, up to 400 inches per second
Scrolling wheel, rubber side grips, sensitivity adjustment, adjustable weight, built-in flash memory, ambidextrous design, 11 programmable buttons, ARM 32-bit processor, Pixart PMW 3366 optical gaming sensor
Cable Length
1.83 m
Microsoft Windows 7 / 8 / 8.1 / 10, Apple MacOS X 10.10 or later
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Logitech G903 LIGHTSPE...
£149.42
