Logitech G920 Driving Force Racing Wheel
£283.89
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Driving Force is designed for the latest Xbox One console racing game titles. You may never race with a regular controller again after you experience G920 Driving Force. G920 Driving Force also works on PC with select titles using Logitech Gaming Software. Download Logitech Gaming Software
  • WORKS WITH Xbox One AND PC
  • Dual-Motor Force Feedback
  • Designed for distance
  • Helical Gearing with Anti-Backlash
  • Easy-Access Game Controls
  • Type: Wheel
  • Wired / Wireless: Wired
  • Compatibility: Microsoft Xbox One
  • Stock Status: In Stock
Product codes
Feel your tires on every turn and type of terrain, sense under- or over-steer drifting. Powerful dual-motor force feedback realistically simulates force effects for precision response.
Driving Force handles the stress of racing action and is built for long-lasting reliability. Solid steel ball bearings in the wheel shaft and stainless steel paddle shifters and pedals make G920 the long-distance race wheel. It's covered in high-quality, hand-stitched leather, with the look and feel of a high-performance racecar wheel and it gives you a more comfortable, durable experience.
Helical gears are modeled after gears used in automotive transmissions to reduce unwanted noise and vibration. Anti-backlash keeps the wheel and pedals tight, maximizing your control. This steering wheel delivers exceptionally smooth, quiet steering action. G920 Driving Force racing wheel features a long lasting, reliable hall-effect steering sensor, using magnetic fields to sense the position of the wheel.
Product Description Logitech G920 Driving Force - wheel and pedals set - wired
Product Type Wheel and pedals set
Connectivity Technology Wired
Features 900° wheel rotation
Designed For Microsoft Xbox One
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Logitech G920 Driving...
£283.89
