Logitech G923 Trueforce Sim Racing Wheel for Xbox & Pc
£378.99
24 in stock
Delivery:
Standard: 1-3 working days
Key features
  • NEXT-GEN SIMULATION
  • CLOSED-LOOP MOTOR CONTROL
  • MORE TRACTION. LESS SMOKE.
  • ON-WHEEL GAME CONTROLS
  • PROGRESSIVE BRAKE PEDAL
  • BUILT-IN REV INDICATOR
  • Type: Wheel and pedals set
  • Wired / Wireless: Wired
  • Compatibility: PC, Microsoft Xbox Series X, Microsoft Xbox Series S
Product codes
FEEL THE FUTURE OF RACING
Meet the next generation of racing wheels. The award-winning Logitech G design is reengineered to dial into your game physics, delivering unprecedented realism. Feel the pistons pumping, the gravel crunching, and every shift, drift, and hairpin turn like never before.
Trueforce - Next Gen Force Feedback
Premium Build - Aluminum, Steel, Leather
Dual Clutch - Launch Assist Control
The latest innovation in force feedback technology connects directly to in-game simulation engines and physics to produce higher fidelity, real-time responses. The feedback frequency range is also increased for dramatically improved detail and realism compared to previous generation
The right current means the right torque. G923’s advanced firmware monitors all the current flowing through the wheel motors, continuously adjusting voltage to match outputs from game physics. By going beyond default settings, G923 delivers pinpoint accuracy and unprecedented realism.
Get off the starting line cleaner and faster with a programmable dual clutch launch assist in supported games.
CRAFTED FOR RACING
The classic design—modernized. The new colorway, premium brushed metal, automotive-style leather stitching, and polished pedals give G923 a professional finish. Form follows function with an integrated center marker and rotary dial
Xbox X/S controls are built right into the steering wheel. No matter how you race, every command is directly at hand.
24-POINT SELECTION DIAL
Traction, torque, brake force—it’s all adjustable from an integrated dial that you control.
More responsive, more accurate. The progressive spring mimics the performance of a pressure-sensitive brake system for a real racing experience. Reposition the pedal faces for heel-toe maneuvers and even more control.
Built-in colored LEDs show your RPM range in supported games. See when you’re redline-ing—right in your line of sight.
DIMENSIONS
WHEEL PHYSICAL SPECIFICATIONS
- Height: 270 mm
- Width: 260 mm
- Depth: 278 mm
- Weight without cables: 2.25 kg
PEDALS PHYSICAL SPECIFICATIONS
- Height: 167 mm
- Width: 428.5 mm
- Depth: 311 mm
- Weight without cables: 3.1 kg
WHEEL TECHNICAL SPECIFICATIONS
- Rotation: 900 degrees lock-to-lock
- Hall-effect steering sensor
- Dual-Motor Force Feedback with TRUEFORCE
- Overheat safeguard
PEDAL TECHNICAL SPECIFICATIONS
- Nonlinear brake pedal
- Patented carpet grip system
- Textured heel grip
- Self-calibrating
MATERIALS
- Wheel spokes: Anodized aluminum
- Wheel cover Hand-stitched leather
- Steering shaft: Steel
- Shifter paddles: Brushed stainless steel
- Mounting clamps: Glass-filled nylon
- Pedal frames and arms: cold rolled steel
- Pedal piston sleeves: Polyoxymethylene thermoplastic
WARRANTY INFORMATION
- 2-Year Limited Hardware Warranty
Product Description Logitech G923 - wheel and pedals set - wired
Product Type Wheel and pedals set
Connectivity Technology Wired
Colour Black
Designed For PC, Microsoft Xbox One
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£378.99
