FEEL THE FUTURE OF RACING
Meet the next generation of racing wheels. The award-winning Logitech G design is reengineered to dial into your game physics, delivering unprecedented realism. Feel the pistons pumping, the gravel crunching, and every shift, drift, and hairpin turn like never before.
Trueforce - Next Gen Force Feedback
Premium Build - Aluminum, Steel, Leather
Dual Clutch - Launch Assist Control
The latest innovation in force feedback technology connects directly to in-game simulation engines and physics to produce higher fidelity, real-time responses. The feedback frequency range is also increased for dramatically improved detail and realism compared to previous generation
CLOSED-LOOP MOTOR CONTROL
The right current means the right torque. G923’s advanced firmware monitors all the current flowing through the wheel motors, continuously adjusting voltage to match outputs from game physics. By going beyond default settings, G923 delivers pinpoint accuracy and unprecedented realism.
MORE TRACTION. LESS SMOKE.
Get off the starting line cleaner and faster with a programmable dual clutch launch assist in supported games.
CRAFTED FOR RACING
The classic design—modernized. The new colorway, premium brushed metal, automotive-style leather stitching, and polished pedals give G923 a professional finish. Form follows function with an integrated center marker and rotary dial
ON-WHEEL GAME CONTROLS
Xbox X/S controls are built right into the steering wheel. No matter how you race, every command is directly at hand.
24-POINT SELECTION DIAL
Traction, torque, brake force—it’s all adjustable from an integrated dial that you control.
PROGRESSIVE BRAKE PEDAL
More responsive, more accurate. The progressive spring mimics the performance of a pressure-sensitive brake system for a real racing experience. Reposition the pedal faces for heel-toe maneuvers and even more control.
BUILT-IN REV INDICATOR
Built-in colored LEDs show your RPM range in supported games. See when you’re redline-ing—right in your line of sight.
DIMENSIONS
WHEEL PHYSICAL SPECIFICATIONS
- Height: 270 mm
- Width: 260 mm
- Depth: 278 mm
- Weight without cables: 2.25 kg
PEDALS PHYSICAL SPECIFICATIONS
- Height: 167 mm
- Width: 428.5 mm
- Depth: 311 mm
- Weight without cables: 3.1 kg
WHEEL TECHNICAL SPECIFICATIONS
- Rotation: 900 degrees lock-to-lock
- Hall-effect steering sensor
- Dual-Motor Force Feedback with TRUEFORCE
- Overheat safeguard
PEDAL TECHNICAL SPECIFICATIONS
- Nonlinear brake pedal
- Patented carpet grip system
- Textured heel grip
- Self-calibrating
MATERIALS
- Wheel spokes: Anodized aluminum
- Wheel cover Hand-stitched leather
- Steering shaft: Steel
- Shifter paddles: Brushed stainless steel
- Mounting clamps: Glass-filled nylon
- Pedal frames and arms: cold rolled steel
- Pedal piston sleeves: Polyoxymethylene thermoplastic
WARRANTY INFORMATION
- 2-Year Limited Hardware Warranty
Product Description | Logitech G923 - wheel and pedals set - wired | Product Type | Wheel and pedals set | Connectivity Technology | Wired | Colour | Black | Manufacturer Warranty | 2-year warranty | Designed For | PC, Microsoft Xbox One |
General | |
Interface | USB |
Colour | Black |
Game Controller (1st) Details | |
Type | Wheel |
Controls | A button, B button, D-pad, X button, Y button, Xbox button, L1 Button, L3 Button, R1 Button, R3 Button, R2 Button, L2 Button |
Features | 900° wheel rotation, LED indicator, programmable buttons, TRUEFORCE feedback, 24-point selection dial |
Game Controller (2nd) Details | |
Type | Pedals |
Controls | Foot pedal |
Features | Auto-calibration, brake pedal progressive resistance, carpet grip system |
System Requirements | |
OS Required | Microsoft Windows 7 / 8 / 8.1 / 10 |
Miscellaneous | |
Included Accessories | Power adapter |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Compatibility Information | |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
